Steering Wheel upgrade
Old 01-04-2020 | 03:03 PM
Desparado85's Avatar
Desparado85
Upgraded to 2013 steering wheel from a 2009 which was worn and the trims peels off as we all know !
KellingFrenzy (01-05-2020)
Old 01-05-2020 | 12:39 PM
takemorepills's Avatar
takemorepills
Looks much better! How's your dash holding up?
Old 01-06-2020 | 02:35 PM
Desparado85
THe dash is holding up very well !
Old 01-06-2020 | 03:13 PM
ILM-NC G37S's Avatar
ILM-NC G37S
If only the dash were as easy a swap as the steering wheel is/was.
Desparado85 (01-08-2020)
Old 01-08-2020 | 12:32 AM
Joyryde's Avatar
Joyryde
Not that hard to remove and put in the dashboard, if you have the extension tool for the socket wrench. I could do it again in an hour or less. The only hard part is finding the best used dashboard.
Old 01-22-2020 | 02:35 PM
FoundersArms's Avatar
FoundersArms
Did you disconnect the battery?
Old 01-22-2020 | 03:04 PM
Desparado85
Yes then wait at least 15 mins before disconnecting the airbag
ILM-NC G37S (01-23-2020)
Old 01-23-2020 | 10:23 AM
ILM-NC G37S
Removing the steering wheel is very easy. Just remember that you will need a T30 Torx security bit to remove the two bolts securing the airbag to the steering wheel. Or, if your car has the anti-theft bolts, make sure you have the right key.
When I swapped to a 2018 Q60 wheel, the whole project took less than 30 minutes.
Mathew Prindle
12-09-2019 12:26 PM
dbl07
06-20-2018 06:18 PM
tomro99
07-30-2014 05:07 PM
Quick Reply: Steering Wheel upgrade
