Help: Releasing coolant vapor bleed
theres a bleeder valve on the uper driverside of the radiator on all 2nd gen G's. you have to remove the driver's side air intake box to get to it. Some earlier 2nd gen g's also have a bleeder valve on the passenger side heater hoses going from the back of the block to the heater core. behidn the block
i dont recall removing the airbox to removed the bleeder valve on the radiator. i could be wrong i did it so long ago. but if you want you can install a bleeder valve on the heater hose like the first gen (plastic one) or buy one from z1 its aluminium goes in the same spot
G37_4DR
11-12-2017 12:03 PM
PDG
General Tech Questions
08-23-2017 07:27 PM
tite_tite
09-25-2015 10:21 PM
