hellp
But the brakes are LED? the only bulbs existing in the tail light are the turn signal, reverse light and the bulb that blink when you lock the car
UCLAg37
I would be willing to bet that there is a connection or trace on the LED circuit board going bad. Just as some of us have the flickering LED's in the gauge cluster, apparently the tail lights are also subject to this problem. So much for LED's being so great.
It will not hurt to test the wiring harnesses. As mentioned by UCLA, use a multimeter or PowerProbe. If they check out good, you will either have to crack open the tail light and check the circuit board or just replace the tail light.
