Reverse Power Wire??
So I'm trying to install my KP mirror tilt module. I need to tap into a "reverse wire"; one that reads 12 volts when you put the car in reverse. I saw a thread on the KP forums that says it's and orange wire located in the driver kick panel. Considering there are probably over a hundred wires down there, I wasn't exactly able to narrow it down.
SO, I removed the gear changer trim panel. I found these wires. However, they all measured ~13.5 volts for all gears.
I found these wires that appear to be the ones that send signal to the little gear indicator lights, but I wasn't able to measure the voltage because I couldn't get the probes inside the connector. Because the forum I mentioned said it was an orange wire, I posi-tapped into it and that wasn't it..
So with that, I ask, can anyone point me in the right direction please?
