Sponsored By:
Sponsored By:
HELP: Beluga axleback on GCC Spec G37s?
Old 07-20-2016, 08:17 AM
zeeshanmalik08
zeeshanmalik08's Avatar
Is this how your stock G37s exhaust's rear end look like? (Just the design) This is how my car's exhaust looks like and I am pretty sure it is not aftermarket (my car is GCC Spec though if that makes any difference?)
I am asking because I want to install Beluga axleback (picture below) and I don't know how it would fit on this exhaust design.
Old 07-20-2016, 08:42 AM
Received 4,942 Likes on 4,175 Posts
As long as you have the OEM Y and mid pipes you'll be fine, here's a pick of OEM setup
zeeshanmalik08 (07-20-2016)
Old 07-20-2016, 08:51 AM
zeeshanmalik08
Thanks! Yes that's exactly how the exhaust looks like. But where exactly will the axleback be attached because behind the rear muffler there is single bolted connection with the Y pipe? Or did I get it wrong...
Old 07-20-2016, 10:17 AM
Presto
Presto's Avatar
the oem exhaust posted above will break apart into 3 pieces. starting from the front the Y shaped pipe, the piece following it and finally the axleback part (the bolts cannot be seen as the pic is taken from rear of exhaust). I am guessing the beluga one replaces the axleback part. just make sure the beluga one is for a g37.
zeeshanmalik08 (07-21-2016)
Old 07-20-2016, 12:54 PM
Landshark
Landshark's Avatar
no, your exhaust does NOT look like that - here is your exhaust pic from the other thread:
you have some sort of CATBACK exhaust, where the rear AND mid pipes have been replaced. the Beluga axleback will not attach to this.
350z_drifter
Vendor Want to buy
03-09-2014 06:54 PM
dagenius01
05-23-2013 02:50 PM
Jereguy
Intake and Exhaust
10-15-2009 02:27 PM
Quick Reply: HELP: Beluga axleback on GCC Spec G37s?
