Sponsored By:
Sponsored By:
What did you do to your coupe today?
Old 08-12-2019, 06:04 AM
  #1666
louith
louith's Avatar
The following 2 users liked this post by louith:
Rochester (08-13-2019), The Pope (08-13-2019)
Old 08-12-2019, 03:05 PM
  #1667
slartibartfast
slartibartfast's Avatar
Your "thing" isn't showing for me (probably for the better).
Old 08-12-2019, 06:13 PM
  #1668
jpowersjr2
jpowersjr2's Avatar
I can't see it.... it's Louith, it has to be good lol
Old 08-13-2019, 01:30 AM
  #1669
slartibartfast
[George Takei] Oh my![/George Takei]
Saw the tiny placeholder where a thumbnail would go and got your photos to pop up. Ow. Bad, Louith. Bad.
Old 08-13-2019, 05:59 AM
  #1670
louith
louith's Avatar
Sorry to disappoint.
fixed my post hopefully
Old 08-13-2019, 01:03 PM
  #1671
slartibartfast
LOL! I got three photos into your album and saw the rod poking through the block and thought that was your "thing".
Congrats.
louith (08-13-2019)
Old 08-13-2019, 01:07 PM
  #1672
louith
louith's Avatar
Congrats.
lol. i appreciate it
Old 08-19-2019, 01:31 AM
  #1673
Airborne_fister
Airborne_fister's Avatar
Gone
Today we’ll technically Saturday. I sold my G37XS. $9000.00! Reason so low the car had/is out fitted with hand controls so I as a paraplegic could drive it. I am the proud new owner of a Toyota Tacoma TRD OFF ROAD PRO. but I still get to keep my G until the Tacoma is outfitted with my hand controls and a lift kit. So I’ll have it for another 2-3 weeks but who knows.
Old 08-20-2019, 12:36 AM
  #1674
timc00k
timc00k's Avatar
Got my sports spoiler wrapped in CF and installed by ExclusiveVinyl in NYC. They decided to do a mini photoshoot of the car as well.
Old 08-21-2019, 06:24 PM
  #1675
SkysG37
SkysG37's Avatar
Black and blue!
So pretty
The following 2 users liked this post by SkysG37:
darkkon (09-25-2019), timc00k (08-21-2019)
Old 08-21-2019, 06:56 PM
  #1676
SkysG37
SkysG37's Avatar
Driving around without the front facia "bumper" feels so ghetto for the G. But I have to test for leaks before I button it up!
I finally got around to mounting and plumbing my trio of coolers!
been collecting parts and fittings for weeks now...
28 row stacked plate (10an) for the engine oil
13 row plate & fin for the trans
And a plain (oversized) tube & fin for the power steering
Both the oil and trans have pulller fans behind them (yet to be wired)
I had already eliminated the coolant lines running to the throttle bodies and oil filter housing...
GQ57s_stein (10-11-2019), KellingFrenzy (08-26-2019)
Old 08-21-2019, 07:12 PM
  #1677
SkysG37
SkysG37's Avatar
Mounted off the side behind the journey bumper lower openings.
Only partially in front of the radiator airflow.
They just squeeze in with the fans behind them.
Had to cut and tap the AN10 fittings for 1/4NPt to 3/8 Barb on the trans side
Plumbing was straight forward... Noting that the upper inlet in the radiator is the trans out.
I byassed the radiator completely as I live and drive mostly in SW Florida 😎
Only needed one extra quart of fluid
Old 08-21-2019, 07:21 PM
  #1678
Received 4,727 Likes on 3,532 Posts
SkysG37, what are fluid temps now, what are you trying to get to, and what would you do if you got there?
That's quite a thing with the zip ties and the intake filter guard. It's like the poor thing is chained there and being tortured. Perfectly functional, though, keeping it steady I'm sure. Put in new zip ties once a year and call it a day.
Old 08-21-2019, 07:35 PM
  #1679
SkysG37
SkysG37's Avatar
Actually left the coolant adapter under the cooler adapter as it made for cleaner runs off the lines.
Both oil and trans coolers run hot side from the middle out.
And you can see the thermostatic switches on the inlet ports
Not pictured are the plastic flaps I put under the aluminum bumper bar to help keep heat away from the air filters without blocking airflow to the radiator
Old 08-21-2019, 07:42 PM
  #1680
SkysG37
SkysG37's Avatar
Look, there's still room for an intercooler!
Haven't taken a reading till I get the fans wired.
They both have thermostatic valves too. So I'm not stressed about over cooling
I'm just trying to do all the little things one does AFTER they go forced induction. But BEFORE, so I can smile without worries when I hit the go pedal. Plus it helps to psychologically stretch the budget 🤑
It's mounted with actual brackets to the vertical radiator support as Stillen intended. I just didn't like the way it wiggled around.
You should see my GF!
She's always saying I use too many zipties
Quick Reply: What did you do to your coupe today?
