G37 alarm
G37 alarm
Hi,
Anyone know if there is a sensor to adjust sensitivity for the factory alarm system for the G37? Few days ago my alarm rang for the first time due to maybe ground shaking from traffic. I thought the alarm rings only when door is opened or something major happened. Anyone else alarm rang before?
TjG37s (06-09-2021)
Unless you have the OEM accessory "Vehicle Alarm Impact Sensor" (999M2 VU003) our cars alarm system is quite basic: If the door/hood/trunk opens it will sound off. There is no motion or impact sensor.
My guess is one of those door/hood/trunk switches is acting up.
If you have the impact sensor, is located on the lower right (passenger) side, above the BCM module.
Is a small black plastic box with a white trim button.
The trim is VERY sensitive so rotate it maximum 1-2 mm then test the results.
To test the impact sensor, lock the car, wait for 1 minute, then kick the front right wheel to start the alarm.
^^^ I believe so. It was a dealer installed option and I suspect it may be hard to find now.
Here are the install instructions:
Coupe: https://www.infiniti-techinfo.com/as.../S/U/1SU10.PDF
Sedan: https://www.infiniti-techinfo.com/as.../S/U/1SU11.PDF
GroovesMcFly (06-06-2021)
This doesn't have to do with the impact sensor, but when I bought my car the alarm started going off randomly. Sometimes early in the morning or late at night. Once I figured out it should only be going off if a door/the hood/the trunk are opened I figured something must not be sealed correctly. I went out and closed the hood nice and firmly and the problem went away. I know it sounds silly but it's always worth trying the simple solutions first.
I know this thread is old but i had to take mine out because it kept acting up and going off for no reason. Does anyone know if the new sensor they have for the Q50/60 will fit our G37's?
@SonicVQ Thanks for posting those instructions. My 2009 G37 has the impact sensor and it has been so sensitive that a garbage truck rumbling past would set it off. One time I made the mistake of cleaning my windshield while the car was locked and set off the dang alarm. It would go off all the time — especially annoying at 3:00 a.m.
I was able to pull all the plastic panels, find the sensor, and dial it all the way down.
Here's a photo:
Here's the impact sensor. It's tucked up and hard to see.
Here's a photo:
jpowersjr2 (06-07-2021)
The following 2 users liked this post by SonicVQ:
GroovesMcFly (06-07-2021),
