**** keeps breaking
**** keeps breaking
Mod bug is hitting me hard, but crap on my car keeps breaking and I'm spending all my money (that I don't actually have) just keeping the stupid thing running...
Anyone else have good luck like me? brb, I'm going to go play in a lightning storm...
- bought July 1, 2014, 49k miles
- 49.1k miles - baffle in muffler loose, dealership replaced from axle back under warranty
- 51k miles - cruise control starts malfunctioning, ~6 trips to the dealership and they replace: clutch engagement swtich, brake engagement switch, ECU (twice), finally track down problem to a grounding issue on some wire (covered by factory warranty)
- 58k miles - CSC and master cylinder go, not covered by warranty, replaced with z1 elimination kit ($$)
- 60.05k miles - throw a rod through the block, Infiniti won't touch it but quotes me $13K for used engine + labor, z1 came to my rescue again for significantly less. ($$$$$)
- Last week (currently at 65k miles) I noticed a small leak from somewhere in my power steering system... appointment to get it looked at tomorrow. I'm hoping it's just a loose connection (couldn't precisely locate with jack/jackstands, need to get it on a lift). If my rack and pinion need replacing, I'm going to flip my ****
Drop A Gear and Disappear
Lemon law does not apply to used cars if he bought it as is..Also not the same issue he is dealing with.. Why didnt you look into an extended warranty when buying a used car.. I made that mistake once when I bought my 350z nothing but issues..but lucky I was able to give it back to the dealer and buy a new one... Last used car I would ever buy
I was 28 years old when I bought it. It was the first decent car I'd ever bought, and everyone told me it was a bulletproof platform... lessons learned, and I will definitely look into extended warranties on my next vehicle purchase.
I discussed with the dealership about them buying it back during the cruise control debacle, but the issue was cleared up shortly after the discussion. After each issue, I thought: surely nothing worse can happen now... haha!
Just heard back from the mechanic on the power steering. Luckily it was just the fitting between the rubber > copper piping that was bad and leaking. I'll be back up and running in a couple hours!
You aren't kidding... I was on my way home from work. Pulled from a stop light (wasn't running hard), and *boom* at ~25mph in 2nd gear. Everyone asked "did you run it out of oil?" but I had just changed the oil less than 2 weeks ago, and left about 4 quarts in the road when it blew, so I know it wasn't dry, haha. They checked the oil filter to see if it was loose or misthreaded, but it was not.
I asked Z1 to see if they could determine the issue when they dismantled the old block, but they said with 2 big holes and mangled insides, they couldn't find anything conclusive.
Just say no!!!!!
Kind of wishing you bought that extended warranty now
Such catastrophic reports are few and rare on here. In the four years on the forum I think there's been maybe 1 or 2 others that such major issues. Probably more on the 370z site as there's more of those cars and driven harder.
Good luck!
Good luck!
A week later and my power steering is still leaking. Now the dealership is saying the pressure line was clamped improperly (they are blaming the guys who did the engine swap) and needs to be replaced. They want $350 + 3 hours labor, after they've already charged me 2 hours labor for the connections they replaced last week...
I see a pressure hose on RockAuto for $120 (Nissan/Infiniti p/n 49720-JK62C). Any idea how hard this is to replace? I'm guessing I'll need a lift to get at it properly...
