Sponsored By:
Sponsored By:
Advice for future mods
Old 12-25-2015, 01:32 AM
  #31
cellwoot
cellwoot's Avatar
Originally Posted by demo401
yea man adapters are dangerous from what i heard the wider at least. 15mm IMO is the safest route. Run with H&R i got a pair from egay fro 125. Already did the back but will do the front soon. Would be terrible if ur wheel popped off on the road.
Are those headlights DIY or did you have a shop do them for you? I'm loving that look.
Old 12-26-2015, 01:51 PM
  #32
demo401
demo401's Avatar
it was already done when i bought the car from previous owner but he did say he had everything done at a shop. Looks easily enough just gotta split the housing prep and paint. There DYI all over youtube. Hardest part probably is removing the light. Might have to remove the bumper cover
Old 12-26-2015, 01:55 PM
  #33
Ricio1991
Ricio1991's Avatar
I have someone that can customize headlights, does really good job pm me for info
Old 12-30-2015, 07:17 PM
  #34
age_
age_'s Avatar
Very nice! I personally like the way you have it now. Well done! Maybe go with a totally new body kit? Add a splitter on your side skirts and front? Rear diffuser. OEM spoiler looks great also.
Old 01-02-2016, 02:18 PM
  #35
G-MENTED
G-MENTED's Avatar
Drop it a little....
Old 01-02-2016, 04:14 PM
  #36
demo401
demo401's Avatar
No way I got tien coilovers she scraps even at the highest setting right now on certain bumps and driveways I'm happy the way it sits. Kind might wanna get 35 over the 30 I'm currently running
Old 01-04-2016, 05:18 PM
  #37
beng37s
beng37s's Avatar
I need your advice guys. My car is stock exterior wise except plasti dipped wheels and painted calipers. For my next "mod" if you will, should I go with a ts or zele front bumper or a carbon ams duckbill trunk? Let me know what you think.
Old 01-04-2016, 11:56 PM
  #38
demo401
demo401's Avatar
All depends what ur style is if Ure into the racing look then yea. Throw a carbon fiber good too but don't buy VIS racing they are horrible. Get some coilovers
Old 01-05-2016, 07:24 PM
  #39
beng37s
beng37s's Avatar
I'm lowered on eibach springs at the moment. Wish I went with basic coilovers being as the I install price for springs was basically as much as coils.
Old 01-05-2016, 07:38 PM
  #40
bikezilla
bikezilla's Avatar
Here are my calipers, not quite dark bronze but close. They're pretty easy to do. Just sand down the stock ones and paint away.
I like that color.
What color/brand paint did you use and is sanding required?
Seems like a lot of effort to sand off the paint in all those corners and crevices.
Old 01-05-2016, 07:39 PM
  #41
beng37s
beng37s's Avatar
It's called "burnt copper" and made by VHT. I sanded as the paint sticks a lot better.
bikezilla (01-05-2016)
Old 01-05-2016, 07:45 PM
  #42
bikezilla
bikezilla's Avatar
Thanks, did you sand the calipers down to bare metal or just to scuff up the original coat?
Also, did you prime it or just spray the final color.
Did you clear coat it as well?
I have a set of decals, just waiting for a day when I have the time to remove paint and wait for curing.
Old 01-05-2016, 07:52 PM
  #43
beng37s
beng37s's Avatar
Sanded them down pretty well but not over the top. Could've sanded for hours but got them down to the point of a little transparency between the paint and metal. I didn't prime of clear coat so I can touch them up if need be. Hope that helps
Old 01-05-2016, 07:53 PM
  #44
bikezilla
bikezilla's Avatar
How does one measure how close the tire should be to the fender for "the right look"
as far as spacers go? We talking MMs btwn the tire and the upper center edge of the fender?
Someone mentioned above about spacers causing lugs to snap, is there a safe limit or are spacers inherently stressful on lugs?
I have a set of 5mms I'm putting on my kid's Juke Nismo and I want to make sure she's safe.
And I might consider edging out my stock 19" sport wheels on my '13 G
So I guess the question is do I need lugged spacers for any kind of use or only if they are beyond a certain thickness?
Old 01-05-2016, 07:54 PM
  #45
bikezilla
bikezilla's Avatar
Just what I wanted to know. Thanks.
Quick Reply: Advice for future mods
