IPL Rear Bumper Question
Hey everyone,
So I recently purchased the IPL rear bumper and it came without holes, but I need holes since I have a 2011. I was wondering if anyone knows of a template for where to cut the holes. I used the search and found that most people seem to have the opposite problem I do (getting a bumper with holes when they don't want it). Any help would be much appreciated, thanks!
Hey everyone,
I thought the holes for sensors weren't perfect circles, but instead had two sides that were straight and two sides that were curved (correct me if I'm wrong). How did you cut that shape out? Thanks
Hey everyone,
I did the same mod a month ago. The inside of the bumper should have the outline if purchased from Infiniti (look carefully), my friend just used a dremel to drill the holes for me. And yes you are right, they are not perfect circles. Best way is to drill slowly until your sensor can fit in there, doesn't have to be perfect as the ring covers it. If for some reason you can't find it the template, I would suggest matching to your old bumper. The wire should be long enough to allow a little bit of wiggle room, though it might not be perfectly matched if done this way.
Topher9425
12-01-2015 03:00 PM
LevitateWithMe
08-20-2015 05:51 PM
