Sponsored By:
Sponsored By:
Infiniti Consumer Affairs - poor experience
Old 05-30-2015, 12:55 AM
  #211
Gio37
Gio37's Avatar
Originally Posted by Awgd8
Hi guys! I have the same issue like BB, but my car is an EX35 AWD Journey with 5 speed AT with VQ35HR @76k miles. I was quoted $2,800 to fix it. My car is still under Elite extended warranty so they will fix it for free. (Well, I have $50 deductible)
One of our EX35 forum members also had his EX35 fixed with the same issue, but his water pump was also replaced since they were going in there anyway. How would I persuade them to change my water pump and other parts that normally wont last beyond 100k miles?
My car is still under Elite warranty next year around Sept. I might trade the car soon when I see a good deal....
I really doubt they will replace a component if it is still working just because it might go out. If you really want the water pump replaced they might charge you for the part and some labor since they are going in there anyways....but hey, never hurts to ask. The worst thing is they say "no"
g/l
Old 05-30-2015, 11:48 AM
  #212
Awgd8
Awgd8's Avatar
Thanks guys for the feed back. Yeah, it does not hurt to ask. I just send her (service manager) an email. I also mentioned I will be shopping for a new Infiniti car early next year...
Old 05-30-2015, 12:57 PM
  #213
If you want a new water pump, buy a new water pump from their dealership and have them install it instead of the original one. They aren't going to just replace a functional part for free under warranty because you want them to. It's not reasonable to expect that. However, you shouldn't have to pay for any extra labor if they have t r/r it anyway for the job
Why are you concerned about the water pump? I'm not aware of there being any problem with failures of that part. At 76K miles you should be spending money on replacing timing parts if anything. That's more likely to be something that has more wear and the amount of labor to go back and replace later would be very expensive.
Old 05-31-2015, 01:25 AM
  #214
00Max00
00Max00's Avatar
Originally Posted by Ryne
This topic has come up in a different thread and it has led me to look into it a little bit. Here is what I ahve found:
I traced the part number of the "revised" gasket that was torn down in this thread, part # 13533-JK21B and the application for that part was the EX35 and FX35 and the VQ35HR engine. It's not a new part at all. I am very confused now.
It does appear that the timing cover and gasket set has gone through several revisions though throughout the years. (13035+A includes the gaskets)
This makes me feel like anyone with a build date in 2012+ appears to be safe. It's likely that only one of these part numbers and build date ranges has the defective gaskets and I'm sure we have enough data here to narrow it down.
Thoughts?
The chart gets me confused. It appears 13500EY00A and 13500EY03B are not referring to different versions of the same part. They are both required.
OUTER TIMING CVR - 2012 INFINITI G37 (13500EY00A)
INNER TIMING CVR - 2012 INFINITI G37 (13500EY03B)
Old 06-04-2015, 03:55 PM
  #215
maxximase
maxximase's Avatar
I just got the dreaded code on my 09 sedan. Car is out of warranty. Local dealer quoted 12 hours of labor to replace the gasket...about $2500 out the door.
Old 06-04-2015, 04:10 PM
  #216
antirice
antirice's Avatar
How many miles on the car?
Old 06-04-2015, 04:55 PM
  #217
That sucks man.
Old 06-05-2015, 03:10 PM
  #218
maxximase
maxximase's Avatar
90k...first and only issue I've had with the car.
Old 06-10-2015, 03:56 PM
  #219
maxximase
maxximase's Avatar
Got the car back today. Got some assistance from Infiniti Consumer Affairs and the dealer which reduced the final bill to just under $1k. I was very satisfied with that resolution.
Old 06-10-2015, 04:37 PM
  #220
Congrats my man. Saved yourself a couple grand. Do you have the invoice? Does it show they replaced the entire rear cover assembly or just the gasket itself?
Old 06-10-2015, 04:46 PM
  #221
sLADe781
sLADe781's Avatar
Awesome!! Would you mind sharing what was said/done when you contacted Infiniti Consumer Affairs to get their help on getting the reduction? Also I noticed you're from the Bay Area as well...which dealership did you go to?
Congrats again!
Old 07-03-2015, 02:38 AM
  #222
NeverBoneStock
NeverBoneStock's Avatar
My P0011 code turned out to be the gaskets as well. But, I took it to a Nissan dealer and they reached the gaskets with the new revised ones, installed my new south bend clutch and flywheel along with my z speed slave, replaced all my leaking valve cover gaskets with the new revised ones, installed my new tranny mount and new CSF 3 row radiator for 2800 out the door. Plus some other misc gaskets here and there and my new polished timing covers. So not complaining that much.,
Old 07-03-2015, 02:40 AM
  #223
NeverBoneStock
I will post my invoice when I pick up the car. They just replaced the T gasket and L gasket with the newer ones..
Old 07-03-2015, 02:55 AM
  #224
obg376mt
obg376mt's Avatar
taking in my car tomorrow to get a warranty inspection before my powertrain runs out next month (currently 09 with 63k miles). going to ask my service advisor if they can possibly take care of this gasket as preventative maintenance and split the cost or even cover it under warranty...
here's to wishful thinking.....
Old 07-31-2015, 02:20 PM
  #225
Marky-Mark
Marky-Mark's Avatar
Yeah reading about all these stories has gotten me so anxious that I was going to sell my car, 09 g37s 63k. However, there is no other car. I test drove many cars and my G is superior to them all. I'm in the Houston area and so far all the Nissan dealers just simply say "we don't do that here, you need to go to infiniti", and all the local shops that specialize in Nissan/Infiniti engines either say they've never done/seen/heard of this before, or laugh and say I'll never experience this issue and that everything on the forums is just a bunch of hot air. For those of you paying $1200, $1500, $2000, and heck, even $3000 I envy you somewhat because infiniti quoted me for $4200. I suppose I can call other dealers and see if it varies. I have not experienced any problems or codes yet though, I don't even know if my OP is low, so I guess I'm going to continue to get quotes because those gasket are bound to go whether tomorrow or 5 years from now. I think my best bet is to try to find a 2013 g37s to trade for when I can find one. It'll be in factory warranty and supposedly has the updated parts.
I think the reason that this is unheard of is because a lot of times this happens under warranty, so it's not a big deal to the driver getting a free fix, and the local shops don't get to see this because warranty work is done at the dealer, but now that 08's and 09's are out of warranty, I think they're going to start to learn how to do this.
Quick Reply: Infiniti Consumer Affairs - poor experience
