Video Inside: Is this the famous windshield cowl popping noise?
Hey guys I just recently got this tapping noise which is coming from the upper dash area. It usually happens when i roll of a bump on the freeway going about 60-70mph. The tapping noise will also be audible when I drive regularly on streets/roads, but would be off and on. I searched around the forums and alot of people are having issues with their windshield cowl producing a noise which is linear with the vehicles RPM.
m0nkey (02-25-2014)
m0nkey (02-25-2014)
The noise only happens when it's colder outside for me. I live in Houston and the last few days have been around 80 according to the car's reading.. I haven't heard it in a while.
And that sounds like the vents are loose in there. If you could try to see if they shake.
I checked it, and its not the issue. It seems like its coming from between the windshield and dashboard area.
FIXED:
While i was installed my air suspension i had to remove the windshield cowl and when i put back the cowl's the noise disappeared. I guess the cowl was missed positioned or one of the push clips was causing the noise.
FIXED:
si_driver
10-01-2015 09:53 AM
