Font License Plate factory tow-hook adapter?
The seller of my car can't find this adapter, so I was going to try a dealership to see if they have one. Odd thing is that I can't find a factory one online anywhere, not even a picture. I have found some aftermarket ones, but they are about $85.
Does anyone have this? There has never been license plate holes drilled into my front bumper and I want to keep it that way.
This is the aftermarket one. The previous owner said that his was just a bar and a little single screw hole for the plate, not a full plate backing like this.
STILLEN Front License Plate Bracket 105465 - INFINITI G37 Coupe & Sedan
Also, this is the 37x coupe, 2009. My front bumper looks like the attached image. The tow hook mount is just behind the black grill insert on the passenger side.
Because Racecar
If you're looking for a bracket that allows you to mount your license plate via a tow hook socket, Stillen is the place to get it.
Not sure what you mean by adapter. It is a full kit that screws into your car and holds your license plate. It does not attach to the OEM tow hook. You'd need to remove the OEM towhook to use the Stillen relocated and vice versa.
There is nothing in the tow hook hole right now, it's just the empty threaded socket.
The previous owner said he had a "rod" that screwed into the tow hook socket, and had a little bar that went across and you screwed just the top-left part of the license plate it, it wasn't a full backing like the Stillen one. He said it was just 1 little bar that stuck off the rod you only had 1 screw to use.
Is this not a OEM part? He said it was what came with the car, and he bought it brand new. Or is he confused and I need to get the Stillen aftermarket one?
Because Racecar
There is nothing in the tow hook hole right now, it's just the empty threaded socket. The previous owner said he had a "rod" that screwed into the tow hook socket, and had a little bar that went across and you screwed just the top-left part of the license plate it, it wasn't a full backing like the Stillen one. He said it was just 1 little bar that stuck off the rod you only had 1 screw to use. Is this not a OEM part? He said it was what came with the car, and he bought it brand new. Or is he confused and I need to get the Stillen aftermarket one?
The Stillen kit is pretty cheap and I will be getting mine soon
timc00k
02-15-2017 09:15 AM
delfinparis
10-08-2015 06:06 PM
