Removing Switch Mask?
Hey everyone, I am planning to do something with the blank switch spot between the heated seat controls on my 2011 Coupe, but I can't see to get the switch out. Has anyone taken it out? What's the best way of doing this without taking the whole center console into account?
This is a picture of the part that is normally there.
it's pretty easy to take out. Remove shift ****, take shifter trim out, open arm rest, slide cup holder/heat seat switches trim forward and then pop up. Disconnect both seat heater harnesses and finally take out the switch cover.
So I figured I would let everyone know because I think it's cool but don't want to disappoint.
The button that I'm mounting there is the mute button for my 9500IX. I know that doesn't sound cool so I wanted to take it to another level. I tried to look for a OEM blank momentary switch but couldn't find anything so I ended up buying this switch.
So now to the cool part about it. The way I am going to wire it will allow for the light to be solid when the radar is on and blinking when receiving an alert..
I thought it was going to be a button, to let out the sharks with laser beams strapped to their heads. Sounds like a good plan though, OP. I like radar detectors but HATE all the damn chirps and beeps they make.
Marine | carlingtech.com
Check out the contura, L and W's, they all fit into the standard size cutouts. Numerous choices for color, dust, dpdt, momentary, etc.
I added a few backlit rockers to my Titan and they simply snap in. My car has the "open/close" switch from the factory
Keep looking, I'm pretty sure they make one. If not check out blue sea systems. Tons of different options for lighting and colors, can have a light that switches on with the dash/instruments or one that turns on/off when it's switched.
