"Flappy paddles" ?
Old 10-13-2013 | 02:37 PM
inyquest's Avatar
inyquest
"Flappy paddles" ?
If you have paddle shifters...
I was just wondering how often do you use them
and
Do you ever use the "manual" stick shift and if so how often?
Old 10-13-2013 | 03:43 PM
socketz67's Avatar
socketz67
I played with them a few times when I first bought the car, but I doubt that I will ever use them as it doesn't feel natural for me to shift with the "Flappy Paddles".
Old 10-13-2013 | 09:17 PM
Roadrash666's Avatar
Roadrash666
I'm waiting for my wifes 370 to get broken in so I can determine if I like them enough to add them to my G. I do use the stick in DS mode when I want more control over the shift points. And I use it pretty often.
Old 10-13-2013 | 11:36 PM
KAHBOOM's Avatar
KAHBOOM
Super Moderator of Pwnage
I drive with them most of the time... well that is I use the gear stick. But in the curves and up in the blue ridge mountains I use the paddles.
Old 10-14-2013 | 12:09 AM
RA081224's Avatar
RA081224
and
In commute traffic, DS mode and the paddles actually make the shifts more erratic so I usually leave it in D mode and leave the paddles alone. However, when i get on the road outside commute traffic or on a winding road, I use the paddles all the time. Ive used the manual stick only once. The shift up and shift down directions are bass ackwards from every other manual valve body automatic i've driven so I just leave it alone.
Old 10-14-2013 | 09:23 AM
monytx's Avatar
monytx
Like KAHBOOM 9 out of 10 times I'm using the so called manual mode. Only around curves I use the slapsticks
Old 10-14-2013 | 12:13 PM
rmfnla's Avatar
rmfnla
Same for me.
Over the years I've gotten good at using the accelerator to manipulate gear changes faster than anything I could do with my hands, so that's what I do...
Old 10-14-2013 | 12:50 PM
ItalianG37xS's Avatar
ItalianG37xS
I leave it in DS mode all the time as it downshifts more when breaking and again I really only use the paddle shifters to downshift so I can hear the exhaust as I pull up to lights. Other than that I just smash the skinny pedal and drive. Haha
Old 10-14-2013 | 02:21 PM
blackfunk's Avatar
blackfunk
I'm more concerned with the downshift 'left' paddle. It by far the one I use the most and trust me I use it alot. LOL
Old 10-15-2013 | 08:50 PM
delorean's Avatar
delorean
LOL flappy paddles... do they ever get "stiff"?
Old 10-15-2013 | 09:01 PM
iGGy37S's Avatar
iGGy37S
If the roads are twisty and you are going at a higher speed, the paddles are quite handy because holding the wheel with one hand can get tricky. Otherwise I use the gear lever.
Old 10-15-2013 | 11:14 PM
gimpy's Avatar
gimpy
During local stop and go driving I rarely use them, but on open roads and the winding roads I enjoy playing with them.
Old 10-17-2013 | 08:59 PM
Skyfox16's Avatar
Skyfox16
I wanted to add these to my coupe but after reading some of these posts i really wonder how often i would actually use them.... has anyone regretted adding them?
Old 10-19-2013 | 05:42 PM
gsm026's Avatar
gsm026
I assume that the 7AT still has no first gear kickdown (like on my '09). That was the primary time I used the paddles - when I found myself in 2nd gear going 10 or 15 mph. Grab the paddle, drop it into first and away you go. Of course you do that, you are stick in manual mode temporarily, so you have to us the other paddle to shift up.
I like my manual better, tho ...
Old 10-19-2013 | 08:36 PM
trp244's Avatar
trp244
I recently added paddles to my 09 x coupe, and I say if you enjoy "spirited" drives on open roads then get them. They def make the drive more involving and fun, while allowing you to keep your hands on the wheel. Just be sure to install a grounding kit too. From my experience it cuts down the wait time between shifts considerably.
Quick Reply: "Flappy paddles" ?
