Part # or name that connects front bumper to fender above headlight?
Does anyone know the part number for the plastic piece that sits right inside the front bumper above the headlight that helps connect it to the fender? I believe there is a metal piece on the fender side which uses a screw/bolt to secure with the plastic piece on the bumper side.
I'm thinking it's part #11 in the attached diagram but I'm not certain and plan to order this part online. Any help would be much appreciated!
EDIT: It is the plastic piece I circled in red in the second picture. I also forgot to mention that I have the IPL front bumper if that makes a different in the part #.
I couldn't find the part number but I found what it's called and how much it is from my purchase history.
Description Qty Price Core Price Total Price
Collision Catalog - 2008 - Infiniti - G37
body hardware, front bumper, bumper & components, stiffener COUPE, CONVERTIBLE, W/SPORT TRIM, 2008-10 Right 1 $30.72 $0.00 $30.72
Status: Sent
body hardware, front bumper, bumper & components, stiffener COUPE, CONVERTIBLE, W/SPORT TRIM, 2008-10 Left 1 $31.93 $0.00 $31.93
Status: Sent
Hope that helps!
Status: Sent
Status: Sent
Hope that helps!
TakmaN (10-10-2013)
![Name: BumperExplosionView_zpsfff33273.jpg
Size: 234.4 KB](https://www.myg37.com/forums/attachments/g37-coupe/150612d1501296034-part-or-name-that-connects-front-bumper-to-fender-above-headlight-bumperexplosionview_zpsfff33273.jpg)
I believe you need part #5 and #16 in the factory service manual, which is the bumper side stiffener that connects with the metal bracket you mentioned.
From sewell infiniti parts, I believe the correct part #s are:
62059JL00A
62058JL00A
Found here:
2012 G37 Coupe: OEM Body (Front, Roof, & Floor) (FRONT BUMPER SPORTS) Replacement Parts
The stiffener from the coupe Sport fits the Aero/IPL (I did my swap last Wednesday).
TakmaN (10-10-2013)
Hey TakmaN, did you order that part #5? I need that exact same white plastic piece and I'm having the hardest time figuring out which part it is in that diagram.
leanlikeacello
08-15-2015 02:14 AM
