Crazy Whistling Noise
Hey whats up guys, I'm hearing this crazy whistling sound coming from either the front or rear driver side of the car was i'm driving. I took it to the dealership and had them check it out, they had no clue what it is, they said it could just be the tires, becuase they're pretty worn. But this weekend i'm planning on just putting a different set of oem rims from a g35 with newer tires, to check if it's the actual tire. I also think it could be something from the brakes, either the pads need to be changed or something else is wrong. It's a small annoying problem, but its just annoying because i can hear it doing highway driving, or city driving. I don't want it to turn into something worse. Does anyone have any ideas to what it could be?
sprix (10-04-2013)
Because Racecar
Have you noticed it's from driving at a particular speed? If it only happens when you drive quickly, it's probably a piece of trim or something that is catching the wind just right. If you notice it at slower speeds, it might be something with your brakes. I doubt you'd notice brake squealing when your wheels are spinning at 50-60 mph. Alternatively, the soundproofing might be loose somewhere and just allowing normal wind noise in from a particular location.
its just when i'm driving in general, when i'm driving in the city or highway. For me to actually hear it the window has to be open as well. I think it's something to do with the breaks, but im going to check it out this weekend. Side topic: Anyone from NY going to slammed by the bay?
si_driver
10-01-2015 09:53 AM
