2013 Change for NISSAN OIL
Looks like they changed it around, they don't recommend there oil anymore
ENGINE OIL AND OIL FILTER RE-
COMMENDATION
GUID-5DAF484B-5225-4882-BA4B-DB4830EFE0AF
Selecting the correct oil
GUID-7E56B07C-FA31-476B-909A-6FD2C08A7626
It is essential to choose the correct grade,
quality, and viscosity engine oil to ensure
satisfactory engine life and performance,
see
Capacities and recommended fuel/
lubricants
(P.9-2). INFINITI recommends
the use of an energy conserving oil in
order to improve fuel economy.
Select only engine oils that meet the
American Petroleum Institute (API) certifi-
cation or International Lubricant Standar-
dization and Approval Committee (ILSAC)
certification and SAE viscosity standard.
These oils have the API certification mark
on the front of the container. Oils which do
not have the specified quality label should
not be used as they could cause engine
damage.
Oil additives
GUID-11AD1E70-8EAE-4D70-880A-3AA3882862D5
INFINITI does not recommend the use of oil
additives. The use of an oil additive is not
necessary when the proper oil type is used
and maintenance intervals are followed.
Oil which may contain foreign matter or
has been previously used should not be
used.
Oil viscosity
GUID-6FE50DBA-A088-4DF7-B955-855B7BC409B7
The engine oil viscosity or thickness
changes with temperature. Because of this,
it is important that the engine oil viscosity
be selected based on the temperatures at
which the vehicle will be operated before
the next oil change. Choosing an oil
viscosity other than that recommended
could cause serious engine damage.
Selecting the correct oil filter
GUID-FFA0543F-C4EE-4AB0-A3D3-B35085A1CBFE
Your new vehicle is equipped with a high-
quality genuine NISSAN oil filter. When
replacing, use the genuine oil filter or its
equivalent for the reason described in
change intervals.
Change intervals
GUID-9DC392AF-E881-459C-941F-E42A7567649C
The oil and oil filter change intervals for
your engine are based on the use of the
specified quality oils and filters. Oil and
filter other than the specified quality, or oil
and filter change intervals longer than
recommended could reduce engine life.
Damage to engines caused by improper
maintenance or use of incorrect oil and
filter quality and/or viscosity is not covered
by the new INFINITI vehicle limited warran-
ties.
Your engine was filled with a high quality
engine oil when it was built. You do not
have to change the oil before the first
recommended change interval. Oil and
filter change intervals depend upon how
you use your vehicle. Operation under the
following conditions may require more
frequent oil and filter changes.
repeated short distance driving at cold
outside temperatures,
driving in dusty conditions,
extensive idling,
stop and go
rush hour
traffic,
Refer to the
INFINITI Service and Main-
tenance Guide
for the maintenance sche
COMMENDATION
see
lubricants
damage.
Oil additives
used.
Oil viscosity
change intervals.
Change intervals
ties.
extensive idling,
stop and go
rush hour
traffic,
Refer to the
tenance Guide
inspector94
09-08-2015 12:57 PM
