Torque specs
Old 05-18-2013 | 09:23 AM
el mono cochino's Avatar
el mono cochino
Torque specs
Hi guys,
I'm doing my brakes today, and can't seem to find in the shop manual where the torque specs are. Maybe I'm blind, but I thought I looked through the entire BR section, and all I can find is "tighten to the specified torque setting". Which is where?
In another one of the many PDFs?
Thanks,
B
Old 05-18-2013 | 12:42 PM
They are typically on the exploded diagrams in the FSM.
Old 05-18-2013 | 12:48 PM
el mono cochino
Right you are. I didn't look close enough. 85 and 43 ft lbs for rear mounting bolts and slider pins respectively.
Old 05-18-2013 | 11:22 PM
el mono cochino
I finished the job this afternoon, not too bad with the right tools. The rear caliper lower mounting bolt was a bit of a pain, being behind the arm where i couldnt get with the gun.
I have 2 questions about the job, as it's been a couple of years since I last did brakes.
After the initial bed in of the pads, I decided to go through an alley with the windows down to listen for and problems. I noticed the pads sound as if they are dragging on the rotors slightly. I say slightly because I only notice it in the alley, and it is not that loud. Is this normal for a while until everything sets in? How do i know if the bedding in process was successful?
I know this next question has been asked before, but depending on where you go, I've seen different answers. Front and rear pins have a plastic or rubber bushing near the end of only one pin per caliper. I didn't notice it until I was cleaning and re-greasing them. What is this for, and does it go to the leading or trailing side of the caliper. What will I notice if they're in the wrong spot?
Cheers,
b
And thanks again Black Betty for the Power Stop recommendation. Here it is complete:
Old 02-21-2016 | 05:07 PM
CodeGuru's Avatar
CodeGuru
Not quite the right torque...
For those who may see this in the future, these values are actually specified in the Factory Service Manual (FSM) as follows:
84.3 (8.6, 62)
43.15 (4.4, 32)
That is:
84.3 N-m (8.6 kg-m, 62 ft-lb)
43.15 N-m (4.4 kg-m, 32 ft-lb)
Units matter!
Old 02-21-2016 | 05:10 PM
Selym's Avatar
Selym
84.3 (8.6, 62)
43.15 (4.4, 32)
That is:
Units matter!
Amen. I go over the ft-lb values with a highlighter to avoid this sort of mistake.
Old 03-01-2016 | 01:20 PM
Stachuu's Avatar
Stachuu
I snapped the bolt that goes inside the caliper cylinder last year while replacing pads, I was lucky to spin the broken part inside the little cylinder and get it out.
Guy at autozone matched the replacement from another car which fit perfectly.
What a Sunday that was..
misc
29
05-24-2023 03:57 PM
conkus805
ECU Tuning / Dyno Data
46
11-19-2015 07:49 PM
faze2988
10-07-2015 12:05 AM
Murkr
09-28-2015 10:45 AM
Quick Reply: Torque specs
