Hood release clip stuck
just finished installing my midnight grill on my g37 IPL and i must have pinched the hood release cable on the passenger side. When i use my hood release under the wheel, the drivers side spring releases the hood but not the passengers side.
i'd read how a few people have been able to go through the grill to pull the cable manually. anyone have any pictures of where this cable is located? i really want to avoid the drive to the dealership if i can.
Just a thing I did to get it unstuck. Have another person pull the hood release as your in front by the side that wont release. Gently put your finger pr fingers under the hood and lift. Happened to me when I too installed my Grill yet Gen 3. Dont pry it up it should just come up with a lil push on lifting.. then fix the cable and all done.
Touchy cable it is...
Good luck!
Good luck!
When I redid my grill, I accidentally pinched the cable with the radiator shroud (the plastic part that has like 129803243 clips you have to remove to get behind the grill). I took the shroud back off and put it back on while ensuring the hood release cable was free (by occasionally pulling on it while installing the shroud making sure it wasn't stuck).
I've replaced my grill before and had the same problem.
Now recently, I changed out all the bolts to some nice stainless steel ones and the passenger side latch was stuck and wouldnt lock/unlock. All I did was loosen the bolts on the radiator shroud and that did the trick. The cable was probably being pinched somewhere under the shroud.
yeah, really wish i had noticed this problem before i closed the hood. now i cant even tell what the problem is, i just assume its being pinched, or it came off when i was reinstalling the shroud without noticing.
i have tried pushing down on the hood while pulling the release cable but it still only works on the drivers side. i'm going to try jiggling it a little more tonight, but its looking like i'm heading back to the dealer to get them to fix it.
The cables are connected through a Y type connection under the drivers side fender. My cable would not release so I had to pull all the cables out and soak them in CLR and then ATF fluid to get the cables to push back so the hood would close and lock into place. Try taking the wire off of the hood latch and attach a vice to the cable itslef and give it another pull that might just do the trick.
great success tonight. i was able to pull on the bumper portion on the passenger side while my friend pulled the hood release cable. this must have freed up the cable enough to release the spring clip and the hood popped up. then i unbolted the radiator shroud and wiggled the cable before reinstalling the shroud. problem solved, thanks for all the advice.
37
10-17-2020 11:12 AM
2012G37
06-03-2018 06:59 PM
Striderx88
10-10-2015 10:42 PM
Msherburneg37xs
Intake and Exhaust
09-30-2015 06:39 PM
