IPL/ Aero kit questions
Hi guys i am about to pull the trigger on an Aero kit for my 2008 g37s, i was on the forum looking for a deal when i came across this https://secure.sewellparts.com/retri...php?quote=1695
, question what are these parts?
1)TANK ASSY-WINDSHIELD
2)LAMP FOG RH x2
my current g37 is stock without lights in the bottom of the bumper,
Sorry i am a newb!
2)LAMP FOG RH x2
Sorry i am a newb!
Wow that was quick, i appreciate it! some follow up questions if you don't mind,
1)why do i have to get the reservoir? not enough clearance?
2) I have fog lights in my headlight, what does this kit entail for fog light mods?
Thanks!
Thanks!
I'm in the same boat as I recently picked up an IPL Aero front bumper but I have a 2008 as well with fog lights in my headlamps. For now, I'm leaning toward not wiring up the fogs and eventually try to get the anniversary edition cover and take out the fogs.
However, if you want to hook up the fog lights on the Aero bumper, member TVPostSound has a great DIY on how he hooked it up with a separate switch. A quick search in the DIY section will bring it up.
I got an 08 and had my headlight spliced with the fog lights. Now when my Auto turns on or when I manually turn it on the fogs come on with the head lights. Careful taking of your front bumper. You have these plastic L shaped stiffners that keep the bumper in nice and fastened that can snap of easily if you are to rough taking the bumper off. There are images on the forum that show the bumper sticking out because the stiffner clip snapped.
2)LAMP FOG RH x2
Sorry i am a newb!
2)LAMP FOG RH x2
Sorry i am a newb!
There's another thread from "Superteeth" about buying a bumper from Sewell.
See if his problem gets resolved before you dive in with them.
What color is your G, you can get all colors for $283, except for Black and White elsewhere.
Edit:
I just saw you had a white one, Superteeth is having an issue with a White Sewell bumper not matching.
Caveat Emptor
Edit:
Caveat Emptor
Edit:
Caveat Emptor
Edit:
Caveat Emptor
Edit:
Caveat Emptor
Regardless, the issue was this, as explained by several people from body shops: Painting a plastic bumper is different than painting metal, somehow. (I would have thought that primer would have kept there from being differences....)
Pearl white is already hard enough to match, but when different substrates are used, the difference is even more obvious. The body shop guys pointed out that the same difference would be seen where plastic is adjacent to metal (for example, the rear bumper to the rear fenders), but it was not as extreme (which was why Austin Infiniti's body shop recommended blending the paint, hopefully under Infiniti's warranty). I even found it between the side skirts and the doors.
That said, depending on how good of an eye you have, you will probably be able to see a difference between the plastic bumper and the metal adjacent to it once you put the bumper on, regardless of the color. The mind is very powerful, and now that you know a difference exists, you will be able to see it no matter what you do.
I know that people with Moonlight White cars should, depending on the paint match from the factory, be able to see the difference on their clean car, especially with the dimming light of a sunset on their car.
Simran Mann
09-13-2015 01:51 AM
