Lots of Wheelspin
#46
I was shocked that I had such traction issues. You would really have to see just how bad the traction was to understand my reaction. I put "only" in quotes (surely I do not need to explain what I meant by putting "only" in quotes). Look again.
#48
I'm bored and have an opinion! (Bad combo!)
The 7AT learns your driving and is speed sensitive.
You will get a nice smooth take off if you slowly depress the pedal down to where the car moves out as you want it to.
Adversely...If you stab it down to the same point you just did slowly...It will jump off the line.
So.....Throttle control. Took me a while to get where I can change the driving characteristics of my G just with how fast I depress the pedal.
Done. Back to being bored.
#49
Im not going to bash this guy at all. I completely see his point. I have a modded 6mt and mine does not light up 1st and half way through second even wheen speed shifting into 2nd. If I punch mine half way through 1st it wont light up the tires. I would have to dump the clutch to light them up like the OP is saying. I have never driven the 7at, so maybe that is the difference here. When I launch my car I can do it at about 3k, get good traction, and throw it into second and get a little wheel spin. Sometimes just a chirp sometimes a little more, but never all the way through second like this guy states. Sounds like you need some new tires OP.
#53
i would keep the burn-outs and hard launches to a minimum. some folks say that its less stress for the car, some say the opposite.
launching puts a lot of stress on the propeller shaft and rear differential.
prior to the g37s, when my girl had a 2005 dodge ram daytona, i begged her to quit launching hard, often. well at around 50,000mile she calls and and tells me she hears a clunking sound when hits the gas, and when she lets off the gas. i crawled under and found free-play in the u-joint right near the differential. she flexed it so hard, that was about an inch of play in the shaft, and a chunk missing lol (should have video-taped this)
#55
Broke the Drive Shaft - YouTube
#56
parkern
10-05-2015 12:12 PM
FlyIce
09-29-2015 04:07 AM
SON415
09-28-2015 05:49 AM
