spun out awd
spun out awd
Its raining here in nj for the past 2 days. I was have a 09x coupe. Yesterday i was at a traffic light and pressed the gas, tires spun before the car went. Today morning I was on a brand new road and reversed to make a "K turn" and tires spun a little. Today right before I was coming home, I was making a left turn and drifted the back tires the whole turn. It felt cool but I dont want that to happen... I got the x for that reason... Tires are good. atleast 80 percent thread on them and they are sport tires.
I did a test, I was at a traffic light and pressed my gas kinda had, it spun for a while before it launched.
It was only raining heavy today when i was making the turn, the other times, it rained before i drove so the ground might have been wet.
The thing that confuses me is that it never said slip and showed the little picture on my dash.
Why is this happening? I didn't change my driving habits. Is it just because of the rain or is something wrong with the AWD system because the slip sign did not come on even once?
I will test it again once it stops raining and it is hot out
I can spin my tires with traction control on. In rainy weather even with awd and traction control u can spin very easy if you floor every time...I have 08g Coupe MT, and I don't spin out much unless I really want to floor it... I guess it depends how you drive
first off sport tires have poor wet performance characteristcs, which are usually not too good in the rain no matter how much tread you have left. tires might slip when going over the painted lines in an intersection. if you want better traction then get all season tires.
I have Michelin PSS and they are awesome in the rain...almost as good when it's dry out. They're also a max performance summer tire.
Now...if the OP is still running oem tires, well that's a different discussion.
You need to fully understand how AWD works on these cars. 90% of your power is always gong to the rear. Only time power is sent to other wheels are if the slip light comes on. The AWD does not keep you from hydro planing. AWD keeps you moving. The VDC system will let you spin just a little before kicking in. Because how it works it does not need to send power to the front just because. Its a very smart system.
the AWD system on the g37 is probably pretty primitive compared to some other cars like the evo x/sti and gtr AWD systems with active yaw controls and active centers diffs and everything inbetween
spinning all 4 tires even with massive 265's on all 4 corners wasnt too hard to do in my old evo x with the amount of power and torque it was putting out,
I cant understand how you think the attesa awd is a primitive system. The awd we have in our cars is the same as the GTR although less aggressive.
im sure its not a basic AWD system but there are more advanced ones out there,
do you know if it has a open center diff ?
Driving 101...
It's because it is raining!!!!
You have to ease off the gas pedal when it's raining. These cars have too much power and torque, and will easily spin out if you don't show restraint when the street is wet. And if your tires are worn enough, it will be worse, but new tires will do it too. It doesn't matter whether you have the S, the X or, or whatever system turned on.
And driving too fast in the rain can cause you to hydro plane! ...All this to say that when it's wet...you can't drive the same way you do when it's dry.
Driving 101...
I didnt know if it was the rain or if the awd system shorted out because there was no slip indicator. This was my original question. I drove like this in the rain many times and nothing happened. It didnt rain today, i floored it and the car took off instantly.
Just wanted to know what was up since the slip wouldnt come on.
misc
17
12-24-2019 05:13 AM
Slapshot1
09-27-2015 08:40 AM
