Is Ivory Pearl really white or is it off white??
I am looking to purchase a IP G37 very soon and I wanted to modify it so that it was very similar to this MyG37 member below (I think he is no longer active). My question is I have read his posts and I know for a fact his car is an IP, but I have seen a few IPs in person and it seems like it wouldn't match with white rims like he's got. White on white even a few shades off can be very noticeable. I know it looks good in the photos, but I dont think this member is still active so I can't verify that it didnt clash or no for a fact that he didnt have the wheels custom painted to match or something. Just wanted to verify from any IP owners that when you put IP next something that is actually white it doesn't clash. Thanks.
IP is a pearl, so it will NOT match a glossy or metallic white. In fact, you would be hard pressed to get two body panels painted the same white pearl to look the same. Pearl paint is a 3-stage paint; it is quite difficult to add a new pearl paint and get it to 100% match the existing paint. Even in your example, the front lip doesn't match the bumper, though it is close.
If you wanted to put white rims on a white pearl car, then you should paint the rims the same color as the car. The wheel gap + tire + wheel lip should break up the whites enough that the difference isn't noticeable.
Thanks for the responses. Like I said I think the owner of the car above is no longer and active member so I can only guess and get input...do you think he color matched those rims or do you think it just looks off when you look up close? If I went ahead and got a 2009 model instead do you think it would flow better? I'm really set on white on white because my last car was red with black rims and I want to go a different direction with my new whip. Thanks again.
IP Is 3 stage paint. That guy in the picture , looks like he has a custom job all white 1 paint used and matched with his wheels. Unless it is some kind of special effects on the picture
There is another possibility that guy took this picture in a bright sun that made this car look more white, and his wheels just matched to the body with IP paint.
Thanks for the input folks, I leaning towards having them color matched, but there is still a part of me that thinks that his rims might just be white. Luckily there are tons of pics on the web of his car, but in some they look like a perfect match and in others they look like they could possibly be white....can someone help me eyeball this pic to try and determine if he colormatched the IP or not? I've looked it for hours and I keep going back and fourth:
Pearl paint is almost impossible to match, even if the car is brand new. Even painting plastic (bumper) vs metal (fenders) alone cause a slight mismatch in color. If you look very closely at a brand new Infiniti at the dealership, u can tell the bumpers have a very slight shade if u examine closely. I have moonlight white and I can see it. So if your getting an older used one, whatever it is you paint will be hard to match. Taking it to a legitimate shop will make it very close and you will hardly notice. But as u can see in the photo u posted, the front lip is pretty far off the original color. My guess is that the shop didn't take into account the age of the paint and just sprayed it using the color code which is a big nono when it comes to pearls.
But in your case of rims, I doubt it'll be much noticeable as long as u use the correct color code to paint the wheels. But I'm pretty much just repeating what everyone else has already stated .. lol
I personally don't think it's a big deal putting standard white wheels as opposed to painting it the EXACT same color. Ie. Black cars with flat black paint, etc.. my friend painted his rims metallic silver to match his body and personally I thInk It doesn't look good.
