g37s compressor
g37s compressor
MY QUESTION IS
I HAVE G37S 2008 MY A/C compressor NOT WORKING
I CAN FIX COMPRESSOR OF G37S 2009 OR 2011
IS IT SAME COMPRESSOR I MEAN IF I FIX IT IT WILL WORK PROBLY?????
Call your dealer and check part numbers. They should be the same but I'm not sure.
Yes the compressor is the same. However make sure that the compressor is the part that needs replacement first and make sure you know what you are doing f you are trying to fix it yourself. Automotive air conditioning can be a little tricky unless you are pretty knowledgeable and have some specialized tools. Don't ask me how I know.
Good luck.
Good luck.
