Key Fob Problems
Key Fob Problems
For some reason my key fob is malfunctioning. It wont open my car door sometimes or ill have to press it a million times until it does. ive checked inside the car it still does have battery life but it still does stupid ****. I get forced to open the door with a key! I try charging the key fob in the car but i guess it doesnt work that way? Am i supposed to change the battery or something? If so how do i do that? I am sorry if this problem had been previously addressed on the forum but i couldnt find anything. Thank you in advance..
Try changing out the battery on you're key fob and see if it fixes the problem.
First. The FOB doesn't charge inside the car.
Second. There's no way to tell if the battery has juice in it or not. YES I KNOW there's a warning that comes up, however it is VERY inaccurate as it came on after I had just put a brand new battery in it.
Go to radio shack and buy a battery. It takes like 10 seconds to change it and only costs like $6. That should fix your problem. Don't go to the stealership for it,they'll charge you $20.
Of it doesn't fix it, you may have a bad fob or sensing unit inside the car.
Does it do this ALL the time or just in certain areas? Is it mostly at work, in your driveway or at the local mall? If it is predominantly in certain locations if could be interference.
If all the time, and it is not your battery (which I would replace just to be sure - you can google to see how to open the FOB and replace - super easy) then it could be the FOB itself.
BTW, first time I have read anyone having FOB issues so am leaning towards the battery or interference.
wow no wonder. bmw charges its key fob when you plug it into the car slot but i guess infiniti doesnt. and so the warning in my car for the battery life is just bull? in the case ill just go swap out my battery and see if the problem continues. i have about 2 keys and the fob on my ring so i doubt that could be the problem either. and it happens whenever it wants to. sometimes it may work sometimes it wont work long enough for me to give up and do it manually. thankl you for the suggestions!
Infiniti MIGHT do the same thing but I'm not sure.
if the battery change doesn't work, try opening up your key fob and cleaning all the contacts and rubber parts with alcohol. I had that problem and cleaning them out fixed it
Mine was acting weird, I replaced the battery the other day and the car still gave low battery warning a couple times. I guess it takes a reading a couple times to verify that the new battery is there.
Everything works good now, it's most likely your battery. For me it said I had 25% battery left and it wasn't working already so its quite inaccurate.
