2011 coupe bumper question
My bumper got hit so i might as well change things since 2008-2012 front bumper covers priced the same. This is for the 2011 coupe bumper/ipl/non aero. Will I need the washer fluid tank so the foglights fits under or it won't fit at all with 2008 washer tank? Cause i really dont see the point of having 2 sets of foglights. Plus want to save. Thanks all!
No the fog lights will fit without the washer fluid tank. If you have a older model car like me (have a 08) you will need a new washer fluid tank cause the washer tank will not fit. Check the link below for more info.
https://www.myg37.com/forums/body-in...swap-idea.html
Correct I have a IPL bumper without fog lights right now. Really not thinking about getting any cause my intakes are right there. Also, I want some because I don't want water to go in there when it rains.
You can install the IPL bumper with the current washer fluid but you will not be able to install the fog lights, but if you want fog lights you are going to have to take out the washer fluid. Also, I have no washer fluid in my car. I took mine out.
350zrunnin12s
08-09-2015 09:55 PM
