AC problem !
Old 06-14-2012 | 10:22 AM
jking's Avatar
jking
AC problem !
I turn on my AC and the fans will not blow any air. I even turn of the car start up still the fans don't kick on, anyone have this problem and is this cover under warranty.
Old 06-14-2012 | 10:42 AM
Rad_Slinger's Avatar
Rad_Slinger
Is there a fuse blown?
Old 06-14-2012 | 10:54 AM
DashKid's Avatar
DashKid
well if you turn on the air does it give you a temperature gauge? If so it might be your fan, if it doesn't than it might be your fuse.
Old 06-14-2012 | 12:39 PM
jking's Avatar
jking
Yes the temp gauge works no fan
Old 06-14-2012 | 01:37 PM
fluxemag's Avatar
fluxemag
I had something weird happen where I had the AC on full blast 60, could hear the fans making a ton of noise but nothing came out of any vents. It was like the thing that directs air to feet or face or vent had them all closed. And no, it wasn't the manual closing things next to each vent. I restarted the car and all was well.
But yes, if your AC isn't working that's a warranty item. For me they couldn't replicate the issue. It happened twice and never again fingers crossed.
Old 06-14-2012 | 01:54 PM
criledo's Avatar
criledo
Besides the G37 we also have a Nissan Armada. Last year they had a recall on the motor that controls the different vents, like fluxemag says, it would start blowing out different directions that desired. If that motor is not working properly all vents just might be closed. Also check the cabin filter, could be clogged up.
Old 06-15-2012 | 03:35 PM
jking's Avatar
jking
Update Guys. I have a blown fuse replace it , it went out again took it to the dealer it's the blower motor resistor the guys said it was shot now it works fine
butwhatuptho
10-04-2015 08:51 PM
Msherburneg37xs
Intake and Exhaust
09-30-2015 07:39 PM
MrRiv
09-29-2015 05:59 PM
k19g37x
09-29-2015 03:46 PM
