Notices
Having issues with my window, please help.
Old 05-01-2012, 11:12 PM
FlState
FlState's Avatar
When I open my door the window lowers a bit like normal, but then it doesn't go back up to seal the door frame when I close the door. If i continue to open and close the door, the window continues to lower more and more, as the window never goes up. Has anyone had this issue before? I've had my G for almost 3 years, my car battery is at about 40%, the car starts normal, the same issue is happening to the passenger door. I have to manually close the window, but once I open the door, it slightly opens again.
Thanks in advance for your help.
Old 05-01-2012, 11:19 PM
cruzmisl
cruzmisl's Avatar
Have you performed the window reset procedure?
https://www.myg37.com/forums/audio-v...dow-reset.html
Old 05-01-2012, 11:30 PM
FlState
FlState's Avatar
Thanks man, It's working back to normal. Infiniti shouldn't program our cars to do that, when we disconnect the battery to charge it or to do anything else, because I was a little worried. Thanks again! Take care.
Old 05-02-2012, 08:29 AM
2008G-Man
2008G-Man's Avatar
It's in the manual .....
Old 05-02-2012, 08:49 AM
DashKid
DashKid's Avatar
For future reference please use the search button or go to the technical section cause they have all the answers there.
Old 05-02-2012, 08:52 AM
Rad_Slinger
Rad_Slinger's Avatar
Thnk I'm the only one who actually reads them still haha
Old 05-02-2012, 09:04 AM
Nope. I've read the entire manual for every car I've ever owned. If you've read it you may not remember everything, but in a situation like this you'd probably remember that there's something about this situation in there and could refer back to it to find your answer. If you haven't you can just ask on a forum.
Old 05-02-2012, 10:18 AM
2008G-Man
2008G-Man's Avatar
As BB said, I read them too .... but I must admit I'm guilty of being lazy and will just come to the experts here sometimes.
Old 05-02-2012, 10:29 AM
cruzmisl
cruzmisl's Avatar
Experts? pffff
Drop it and put some 20s on it man.
Old 05-02-2012, 10:33 AM
Rad_Slinger
See....expert answers from experts.
The above answer will fix any problem
Old 05-02-2012, 10:47 AM
dk85
dk85's Avatar
I might wanna switch out the battery soon unless you are still maintaining the OEM water filled battery.
Old 05-02-2012, 02:13 PM
2008G-Man
2008G-Man's Avatar
Red Top all the way ..... great batteries!
Old 05-02-2012, 02:33 PM
mtrsprt
mtrsprt's Avatar
I would never put an Optima battery in anything. Nothing but garbage. IMHO.
Old 05-03-2012, 08:37 AM
2008G-Man
2008G-Man's Avatar
Wow .... I think a whole lot of people would beg to differ .... to each his own.
Old 05-03-2012, 08:56 AM
Rad_Slinger
No...a lot of people have problems with them ranging from no cranking amps, to them only lasting less than a year. Money wasted IMHO. Go to any real auto parts store and if the person behind the counter is honest about heir opinion they'll tell you they're not worth the $$$
At $200 a pop...I'll pass and get the $100 battery that has more CCA with the 3 year warranty.
Quick Reply: Having issues with my window, please help.
