What does it mean to tune?
In many of the Stillin CBE threads I've seen the word "tune" tossed around. What does it mean to "tune" your exhaust. From what I could make of the conversatoin I guess the argument that if you just bolt your exhuats on it won't have the same power as it would if you were to tune it. Something along those lines and clearly idk WTF they're talking about. Does anybody?
Unless you add a turbo or supercharger you not going to get any measurable performance gain from adding an intake or an exhaust. It is quite possible you will lose performance.
in addition, the tune also allows *uprev* to essentially change other parameters as well - you just happen to gain whp by doing so. with our 37's, we also get 100% throttle response as well in addition to a few other small bits and pieces (raising rev limiter)
tuning in a sense just means to fine fix your car's air to fuel ratio. the ecu (brain of the car - that controls such items as afr) has parameters that typically can adjust the fuel ratio to the given amount of oxygen (density) entering the system. when you add breather mods ie intakes, exhaust, test pipes, headers, a tune essentially resets the parameters that the ecu can adjust to the higher volume oxygen coming into your system. unfortunately, you have to realize that the reason for this is because all cars have the same "tune" - ONE map that essentially has to be able to compensate for all potential climates throughout the globe (super hot climates and super cold climates). therefore, your car's ecu map isn't "custom" for you particular car. tune = piggyback = runs off your ecu. does that make sense?
but you are correct, if you don't know what you're doing, best not mess with it.
i gained around 50 hp over stock with my bolts ons...not much to gain my a,s,s anytime you change air going in or air going out of your car you need your tune adjusted. everything is in the tune. if a car is tuned for 91 octane it does no good to put in 93, i have even seen cars lose power. thats the advantage of an uprev tune. i run 94 octane all the time. the guys that say dont waste your money on a tune are the ones that lower their car and put rims on it and then think their s,h,i,t doesnt stink. $500 gets you an uprev license and cable and it only takes 3 etunes to get it set and those are free when you buy it
tuning in a sense just means to fine fix your car's air to fuel ratio. the ecu (brain of the car - that controls such items as afr) has parameters that typically can adjust the fuel ratio to the given amount of oxygen (density) entering the system. when you add breather mods ie intakes, exhaust, test pipes, headers, a tune essentially resets the parameters that the ecu can adjust to the higher volume oxygen coming into your system. unfortunately, you have to realize that the reason for this is because all cars have the same "tune" - ONE map that essentially has to be able to compensate for all potential climates throughout the globe (super hot climates and super cold climates). therefore, your car's ecu map isn't "custom" for your particular car. tune = piggyback = runs off your ecu. does that make sense?
"$500 gets you an uprev license and cable and it only takes 3 etunes to get it set and those are free when you buy it"
That's impressive. What bolt ons do you have and any dynos?
I'd recommend getting a custom tune though. I'm not entirely sure if etuning gives you the different maps (Stock, Security, ECO, Valet and Power) and without an actual afr readings of your actual car with your given mods (not just general readings from other cars with similar mods)...i'm not entirely sure how they custom tune. plus, don't they have to adjust to all the detonation as well?
