Side Mirror Problem
Side Mirror Problem
Not sure what happened today - Black Friday. For some reason I have to keep resetting my passenger mirror to it's regular position. Every time I turn off tbe engine and restart minutes later, I notice it has turned mostly inward. I even tried resetting it with my hand. I'm guessing some large person squeezed in between my car and the one it was parked next to. Something is causing it to reset on it's own. Very annoying.
It's not a problem. Your car must have the memory seat option. Every time you start the car, the mirrors reset back to their saved position. Next time you're in the car, adjust your seat and mirrors as you want them, save it into your Seat Memory 1 or 2, and every time you'll start the car from then, the mirrors will be as you saved them.
My driver side does this to. Even after setting it in the memory time after time. I unlock it with my fob or by the button on the door and the driver mirror comes all the way in.
After I set it in the memory the mirror will stay in the correct location during unlocks but after it sits for a few hours it goes back to rotating in on unlock.
Anyone ever have this issue or know a fix?
photocat
09-14-2015 02:32 PM
SuicidalG37SGuy
09-10-2015 06:01 AM
