Somebody broke into my G37 COUPE HELP! ! ! ! !
I cant believe its so easy to do that? Just pop the cover, play with the screwdriver, windows down........While in alarm locked OEM mode, does that Alarm/Horn go off?
I asked my friends, neighbors, they didnt hear a thing?
How can I test the OEM alarm?
WOW i cant believe its so easy, so pop off the cover, stick in a screwdriver, mess around with it, and windows DOWN? what the hec?
My neigbors didnt hear a thing, should the ALARM/HORN go off if the car is set to lock OEM alarm mode?
How do i test the OEM alarm?
the alarm does not go off...that's exactly how I found my car
Just say no!!!!!
IIRC, this roll down 'feature' is defeatable. The dealer has to program the option out. They'll still damage your lock with the screw driver, but the window wont go down. Question is, will they then knock the window out to gain access, or move on to the next car...
Nobody has ever broken into my car. Will this person/people come back? The dealer can disable this roll down the window feature? I called Douglas Summit Infiniti Auto Body, NJ so Im going to take it there for estimate. MY door makes this weird noise/click noise when I close it, like it something is loose?
#30
So I went out and tried it, my 08 does as so. Iirc, you can open.the trunk from the inside and the alarm won't sound, only if you open the door from the interior will it go off
