Sponsored By:
Sponsored By:
G37x vs G37xS
Old 04-18-2021, 08:27 PM
  #31
Slee
Slee's Avatar
Straight line g37xs or g37s
So I Got a question in a straight line whats faster and g37s or a g37xs a question i haven't been able to find an answer to so I figured I ask the forums
Old 04-19-2021, 06:56 AM
  #32
Received 4,727 Likes on 3,532 Posts
I believe they are so similar as to not matter really. However the xS is certainly faster on mud and snow, whereas the RWD S with LSD is just more fun to drive.
Old 06-02-2022, 09:47 AM
  #33
Mboxer511
Mboxer511's Avatar
I believe the AWD will have an advantage in the beginning as the power distribution is a 50/50 split from a dead stop, which transfers power to all wheels equally. However as the car gains speed the power moves towards the rear until its 100% rwd. At that point, the additional weight from the AWD system might stop it from reaching the same top speed as the RWD car.
Basically in a 1/4 mile race the AWD would be ahead in the beginning but might be .1 sec behind by the end. This is in a perfect situation where both drivers had the exact same timing with their driving, start to finish.
Old 06-03-2022, 05:15 PM
  #34
xorbitman
xorbitman's Avatar
I have a 2012 xS Coupe and it has front and rear LSDs....and when I turn traction control off it doesn't completely turn the nanny off however it allows a bit of fun going around corners while accelerating....and produces a bit of controlled fish tailing.
Old 06-03-2022, 05:31 PM
  #35
Selym
Selym's Avatar
Did you swap the front diff, or did it come with an LSD?
Old 06-03-2022, 06:01 PM
  #36
Somebody with more engineering chops than me can weigh in, however... the AWD G has what's called ABLS (Active Brake Limited Slip). So functionally, it's left-to-right side limited slip behavior. But mechanically speaking... nope. You don't have front & rear LSD.
Old 06-03-2022, 09:57 PM
  #37
Mboxer511
Mboxer511's Avatar
If you have the 2012 xS (which I have too) the front and rear have a Viscous Limited Slip Differential (VLSD). Instead of gearing it uses liquid and clutches similar to a torque converter in an automatic transmission. It's all controlled by the electronic clutch pack (ATTESA E-TS) to transfer power front to back/back to front, and from there it uses 4-Wheel Limited Slip ABLS to transfer power from side to side. Only the S cars have LSD, and only in the rear.
Old 06-03-2022, 10:44 PM
  #38
Epiphany
Epiphany's Avatar
VLSD is still LSD. I'm 99% sure there is no VLSD on any of the awd models, only a VLSD on the RWD models. AWD is open diffs front and rear fairly sure.
Old 06-03-2022, 11:39 PM
  #39
JSolo
Just say no!!!!!
JSolo's Avatar
^^Agreed, I've never heard of any awd models having any sort of lsd/vlsd.
@Mboxer511 can you show some references?
Old 12-15-2022, 12:20 PM
  #40
SCRCMULL
SCRCMULL's Avatar
Limited slip
330 hp
sport seats
different front fascia
19 inch wheels
akebono brakes
Old 12-16-2022, 10:40 AM
  #41
EcstaticG37XS
EcstaticG37XS's Avatar
They're very similar in a straight line. I think the g37s being RWD will pull slowly away at higher speeds mainly because it's lighter.
If I didn't live in a snowy climate I would've preferred a G37S mainly due to the akebonos, LSD, and quick steering ratio.
Old 12-16-2022, 11:20 AM
  #42
The xS Coupe did come with the BBK, and limited slip was approximated through the ABLS system. But you're right about the steering ratio.
Here's the full features list: https://www.infinitihelp.com/models/...ifications.php
You know, if I were looking for a car today without a manual transmission, but with power and features, the xS Coupe would be a fantastic choice.
The following 2 users liked this post by Rochester:
EcstaticG37XS (12-16-2022), SCRCMULL (12-16-2022)
Old 12-16-2022, 08:00 PM
  #43
socketz67
socketz67's Avatar
I did not know this about the xS Coupe as I thought all xS models shipped with the smaller brake package. The AWD vs RWD Sport model feature list is a common source of confusion on the /g37 reddit sub.
This thread cites some references to VLSD being an option on the xS coupe as well: https://www.myg37.com/forums/engine-...-on-awd-g.html
I wonder how rare coupes are which possess the full sport feature set?
Old 12-23-2022, 09:34 AM
  #44
BULL
Moderador
BULL's Avatar
In that trim it seems like there are a few. It seems like this was a 2010-2013 trim, however they continued and possibly released the same or more in V36 Q60S AWD trim.
I think in my city I've seen 1 of these trims and Ake were there. It then threw me off when I started to see the sedan version of this trim did not and also some did not come with a front lip either.
@14Q60awdSPORT might have some more info for us.
G37X NYC
03-11-2016 11:24 PM
gsteigerwald
04-19-2014 09:14 PM
mkirsh
12-21-2011 12:17 PM
johnnyjunco
09-22-2011 04:27 PM
dvader
03-24-2010 11:50 AM
Quick Reply: G37x vs G37xS
