Sponsored By:
Sponsored By:
Problem at start up
Old 06-27-2011, 12:38 AM
asitag
asitag's Avatar
Thumbs down Problem at start up
Guys,
I have been having problems when I press the Engine Start button. Usually, it starts up fine and there are no problems. But, once in a while, it fails to start on the first few tries.
Do you think it's the battery in the key or something in the engine? Any ideas?
Also, when i'm driving, the power seems to dip for a split second. Is the issue related?
Cheers
Old 06-27-2011, 01:14 AM
FM37
FM37's Avatar
The engine start has nothing to do with the key FOB battery...
The key FOB battery gets you in the car/locks the car and there will be an indicator in your dash if it's low.
Sounds like it's your CAR battery or possibly even the starter.
Take it to the dealer man, done deal.
Old 06-27-2011, 01:35 PM
_ant_
_ant_'s Avatar
yeah agreed just take it to the dealer
Old 06-27-2011, 02:38 PM
DjFromVA
DjFromVA's Avatar
^^^agreed
Old 06-27-2011, 03:05 PM
LexiG37
LexiG37's Avatar
Visit the dealer asap
Old 06-27-2011, 06:59 PM
asitag
asitag's Avatar
well...
We don't have infinity here in australia. it's an imported car from japan
has anyone here had the same problems at start up?
Old 06-27-2011, 10:57 PM
IntangibleBW
IntangibleBW's Avatar
I have the same problem.. Haven't had a chance to bring it in but I will be soon.. I'll post back when I find out what's up
Old 06-28-2011, 08:29 AM
myk1013
myk1013's Avatar
Originally Posted by asitag
Guys,
Cheers
well...
I had the same problem a few months ago until I brought it to the dealership. My service advisor told me that a sensor in the clutch pedal needed adjusting. Apparently, the ignition couldn't recognize that the clutch pedal is pressed down because the sensor was misaligned.
I don't think the power dip is related at all to this. My guess is dirty throttle bodies. There's a DIY thread on how to clean them.
Maybe you could bring the car to a Nissan dealership???
Good luck.
Old 06-29-2011, 08:09 PM
asitag
asitag's Avatar
thanks, i will ask nissan. hopefully they can help me out
infinity is due to arrive in australia by the end of next year!
Old 06-29-2011, 08:50 PM
GPR-37s
GPR-37s's Avatar
Nice ahead of the game... probably you have one of the few G's out there....
Old 06-29-2011, 09:34 PM
Topher9425
Topher9425's Avatar
ok....question, with the known battery issue with the G37's, if I had to replace my battery ($149) will Infiniti reimburse me if I call corporate? because it was dead before I got a chance to get to the dealer! LOL
Old 08-06-2011, 09:58 PM
Booboo
Booboo's Avatar
Your battery might be low caused by BCM(body control module) draining it. The dealers in the US will replace both BCM and battery for you but since you are wayyyy overthere then....i don't know. I guess try to talk to Nissan dealer to have them handle the matter or call Infiniti direct. Good luck
Old 08-06-2011, 10:15 PM
Soliditude
Soliditude's Avatar
Guys,
Cheers
It's either your battery or the generator, most likely. Next time your car is ON, take off the (Minus) on your battery; if the car continues running, your generator is fine, but if it shuts down right away, your generator isn't working properly. Unless the generator is bad, it's most likely your battery going out. Pop in a new and see what happens!
Old 08-18-2011, 09:20 PM
jplebeouf
jplebeouf's Avatar
I have the same problem and don't think it has anything to do with the battery. I think it's probably the clutch switch. Until a couple of days ago, it usually started on the first try, with the second try always working. In the last couple of days I've had to press the button more than twice on two different occasions. It never really bothered me and thought it might be common, but now I'm worried that eventually I won't be able to start it at all.
This is the main reason I'm not crazy about push button starts. I do love never having to take my keys out of my pocket though!
Old 08-18-2011, 09:47 PM
eksigned
eksigned's Avatar
^ i'm no mechanic, but could it also be a plug issue? rare, but also a possibility. starters going bad...aren't too common on our particular cars (at least from what i've read). gl!
Quick Reply: Problem at start up
