Why Does Our Belly Pan Sit So Low???
i am so pissed.... i just got low profile tires and with the setting i had it was way to low. So i had to raise the car about finger1/2 and i raised the rear so its a finger gap.. I hate it so much its making me mad.. I just dont want to crack the oil pan but i am about to lower the rear again a little. i just cant stand wheel gap.. my tire specs are 225/45/18 245/40/18
your 45 series tires are 1" smaller diameter so it's 1/2" lower to the ground to start. Sounds like you don't like tire gap so even with normal tires you're probably liking a 1.5"-2" drop. You need to add another 1/2" for the smaller tires showing more gap. In total you are probably 2.5"-3" lower than stock which is pretty freaking low. Go back to 50 series or stock 19's and you can raise it up a full inch and keep the same gap.
yeah i should have!!!!!! uhmm ill figure something out....... i am thinking of just getting 2 differnt tires in the front
uhm what you guys think of 245/50/18 tires in the front and have the 245.40.18 in the rears let me know now. i want more clearance in the front
