Radar Detector hardwire
Has anyone done a radar detector hardwire? Not stealth install. If you have, do you have pics and how did you connected it to the fuse box? Did you use a switched connector or piggy back off of another connection? Was it hard to trail the wire down the A pillar?
Thanks
Thanks
First I am assuming you are using a portable unit typically suction cupped to the windshield. Have you considered the Blend Mount rear view mirror connection? That is a really good solution. I'm not sure where you plan to mount the detector for the hard wired installation. At the roof? I would be concerned about maintaining signal reception based on where it gets located especially if it is designed to receive laser signals from both front and rear.
I just put in a blendmount and invisicord last week. Both work well. Make usre you get the smaller pins and the normal ones will not fit. It is tight.
Looks great. I will try to take pics today and post.
If you're still set on wiring to a fuse. Get an "Add-A-Circuit" from most any local auto store, then just tap into a fuse that is on when the car is on, I chose the one for the radio. My radar detector is one that has sensors mounted in the front/rear of the car so the blendmount is not an option, maybe he has the same?
I hard wired my V1 radar detector to the power supply in the ceiling light consul. You can also find a post from G37racer that show the tap in at mirror jack option.
https://www.myg37.com/forums/audio-v...-detector.html
good luck
good luck
oSnapMillerTime (03-28-2016)
Thanks
Thanks
Sorry man, no pics but it is a snap!
Improvised "invisicord" assembly & install tip for Radar Detector - MyG37
good luck
good luck
Thanks, this seems like a lot less work than running down into the fuse box.
Ran mine with taps into the rear view mirror so I could remove the detector quickly and easily. Zero complaints doing it that way. Mounts via suction cup below the mirror so the rear antenna isn't obstructed.
