So would you guys recommend the H&R DRM (bolt on ones, more expensive) or the DRS (replacement studs, cheaper) spacers? Which ones have the least, if any, vibration when installed?
^^^ nope, as long as your rolling diameter is the same your all good. im probably gunna get some 20mm spacers for the front. weel see after the alignment
The ride on Eibach will undoubtedly stiffen the ride because the lowering the car. IMO it's definitely worth it though for the lower stance and increased handling. I'd also recommend a camber kit so you can be sure your alignment is back within spec.
Simpson, have you had anything problems with rubbing in the rear with the 25mm spacers? And are you using bolt ons or replacement lug spacers? Any vibrations?
agreed on the stiffer ride, but better handling
no rubbing, but i havent got an alignment yet. doing that on friday
my front spacers vibrate a little at 110km/h, but the rears don't as far as i can tell. they are the bolt on type. i might go up to 20mm in the front soon.
