HELP! Shell gas station screwed me!
Bro you will be fine shell is the best gas station gas quality wise!!! the regular is like mobiles premium my father owns a shell and there have been many tests do not even worry bout it. We actually can fill regular gas in our G's and we will be fine it is just recommended that we fill premium it will give us are full potential of our cars and little better gas mileage because the gas doesnt get eaten up as fast. Dont even worry relax
Th grade of shell regular was almost the same grade as mobile premium this is because Shell and and chevron used oil based gasoline while am/pm, mobile, 76 etc use water based gasoline. This is why shell and chevron regular gasoline is almost as good as mobile premium. I over exaggerated when i said its exactly the same thing but they are almost close. This is why shell and chevron is the most expensive gasolines and am/pm and mobile is cheaper. Am/Pm and other comapnies use water based gasoline which means more water then gasoline. the reason why the gasoline still does the job is because the additives put into the gasoline. That why never fill up there not even premuim same with mobile and maybe 76 im not really sure about 76 though. people filling up am/pm mobile etc are asking for car problems fast. U get what you pay for. My opinion people can never go wrong with shell v power or chevron techron both the best gasolines quality wise on the market guaranteed. This is the secret gas companies keep from you. Also it all depends on the additives put into the gasoline to help the engine. Shell and chevron premium fuel was rated number one on that. Shell has nitrogen in all fuel grades also which cleans the engine while running!
Actually, according to the bible (owner's manual) it is required.
Use unleaded premium gasoline with an octane rating of at least 91 AKI (Anti-Knock Index) number (Research octane number 96). If premium gasoline is not available, unleaded regular gasoline with an octane rating of 87 AKI number (Research octane number 91) may be temporarily used, but only under the following precautions:
● Have the fuel tank filled only partially with unleaded regular gasoline, and fill up with unleaded premium gasoline as soon as possible.
● Avoid full throttle driving and abrupt acceleration.
#29
Thanks for all the information guys. I spoke with the store manager today and he offered to take the gas out of the car with a hose/pump and refill it with the 91 octane.
Honestly, I think this is more trouble that it's worth. At this point, I'm okay with just driving the car like a grandma until the next fill up. All I wanted is just a $50 gas card for my troubles or at least a refund, but the manager said he can't do that because of "inventory." If I wanted a refund, he'd have to suck the gas out of the car and process a refund due to inventory issues. I'm sure that's much more cost-efficient than just processing a refund. He also told me that their 91 is just a combination of the 87 and 89 mixture... which makes no sense to me. I feel like he's just trying to avoid responsibility for this and this is more of a matter over principle that anything else.
