changing oil every 7500 miles
Old 02-21-2011 | 06:05 PM
JohnnysG's Avatar
JohnnysG
Originally Posted by Felix_the_Cat
I agree with hispeed look at his post count the guy has seen a million people start oil threads and they all get deleted or merged with the main one you should of looked in from the beginning... This thread probably won't last long
Lasted long enough to get his answer
Old 02-26-2011 | 02:22 AM
IPL - NYC's Avatar
IPL - NYC
OMG people!
Let me ask you a question...When you stink do you take a shower?
A car is the same f'ing way. Roll up your sleeves every 1K miles or so after the first 3K miles following an oil change, pull out the dip stick and take a napkin to the oil. If its still golden even slightly, your good. If its dark brown, its time to replace your oil. Its not rocket science and as long as you routinely change the oil your going to be fine and will not cause your engine damage or lose performance.
Rule of thump. If you use standard oil, change every 4-6K miles. Any less and its a waste of money and time -- literally. If you use synthetic, change every 8-10K miles.
timc00k
09-05-2015 05:12 PM
Sway_NV
22
08-29-2015 04:58 PM
G37xS-Life
08-24-2015 12:08 PM
Mattlorentzoe
08-21-2015 05:09 PM
cellwoot
08-13-2015 04:27 PM
Quick Reply: changing oil every 7500 miles
