Sponsored By:
Sponsored By:
Warm up on cold mornings
Old 02-04-2011, 12:02 PM
kavione
kavione's Avatar
Am I the only person that lets the engine run in the morning to warm up before starting to drive?
Old 02-04-2011, 12:12 PM
Steveo47
Steveo47's Avatar
nope, no matter what, even if im late, i let the g warm up until i see the temp needle go above the lowest tick, then i drove slow for a bit to get some heat in the transmission. Im a bit crazy about my g though. Lots of people just drive away
Old 02-04-2011, 02:17 PM
beerme986
beerme986's Avatar
i just start and drive but I keep the rpms low until it warms up.
Old 02-04-2011, 02:22 PM
TheIvoryG
TheIvoryG's Avatar
Been discussed quite a bit...here is the most recent thread about it...
https://www.myg37.com/forums/g37-sed...up-your-g.html
Devildog37
Devildog37's Avatar
I always run out and start my car about 5 minutes before I need to leave. By the time I come back out, everything is nice a warm and the engine is in it's normal temp range.
Old 02-04-2011, 02:30 PM
BooSa37
BooSa37's Avatar
Always let it warm up no matter what.
Old 02-04-2011, 02:34 PM
eksigned
eksigned's Avatar
yeah. i do the same. if i'm in a big hurry, i wait for the minimum 30 seconds that the manual calls for. then i easy out. shift at around 3000 rpms...anything under and the cold transmission lurches. have to be easy going into 2nd as it doesn't go in as readily when cold. it's sort of annoying. considering an auto start. not sure how i'd bypass the clutch though....
Old 02-04-2011, 03:01 PM
rks
rks's Avatar
I let it warm up until the Ark quiets down just a little (about 1 minute).
Old 02-04-2011, 03:56 PM
JoshLee89
JoshLee89's Avatar
No matter how late I am, I always turn on the engine first, wait till rpm goes down . usually 45 sec to 1 min (depends on weather) and drive slowly under rpm 3k till temp comes up to normal range.
I also turn my engine off after I leave the gears at P for about 30s to 1min.
Old 02-04-2011, 04:03 PM
cruzmisl
cruzmisl's Avatar
I'll wait for the revs to drop after start-up, but then I'm off.
I'll keep revs low until the engine temp goes up to normal. On our cars, that happens within a few minutes.
Old 02-05-2011, 04:01 AM
maxfinity
maxfinity's Avatar
I wait until the old diesel sound goes away(about 30 seconds) then its slow going until coolant temp rises.
Old 02-05-2011, 04:31 AM
Obvis07
Obvis07's Avatar
u dont have to let it idle for so long. its not really necessary just like 10 - 30 seconds and dont race out
Old 02-05-2011, 09:34 AM
RedG37SNC
RedG37SNC's Avatar
+1^ I warm it up cruising out the neighborhood.
Old 02-05-2011, 12:52 PM
tudernos
tudernos's Avatar
Should I Let My Car Warm Up Each Morning?
Old 02-05-2011, 12:55 PM
Breitling65
Breitling65's Avatar
I remember that from my college time - not much difference for internal combustion engine to stay and warm or drive slow rpm and warm. However if temperature is very cold I do warm couple of min staying near to home. Remember transmission oil and other parts need warm up as well.
Quick Reply: Warm up on cold mornings
