how to change oil?
Old 01-29-2011 | 11:02 PM
chogrilla's Avatar
chogrilla
Question how to change oil?
can anyone explain how i can change my car oil myself. ive never done it and hoping to learn
Old 01-29-2011 | 11:57 PM
hispeed-lowdrag's Avatar
hispeed-lowdrag
Honestly, changing the oil in this car is cake. Open the manual and follow it step by step and you can't go wrong. Its very clearly explained how to, you can also read through the oil section here.
Old 01-30-2011 | 12:19 AM
Steveo47's Avatar
Steveo47
its easy, i had a problem using the oil filter wrench the first time, but do what i did, buy a 1 inch wrench and k&n oil filters, that nut on the top changed my oil change time from 30 min to 10.
Old 01-30-2011 | 01:35 AM
breftayka's Avatar
breftayka
At the bottom of the engine, there is a drain plug. Loosen with a socket, but ensure you have a drain pan or some kind of container underneath. Replace drain plug when it has finished draining. Replace filter, and then fill engine with oil...
Old 01-30-2011 | 01:37 AM
jujubii's Avatar
jujubii
2003-2006 Infiniti G35 Sedan Engine Oil and Filter Replacement Procedure Video
goodluck
Old 01-30-2011 | 03:57 AM
g37cam's Avatar
g37cam
You know they didn't make G37's in 2003-2006.
Old 01-30-2011 | 04:39 AM
6mtg37s's Avatar
6mtg37s
the370z also has a DIY oil change post.
Old 01-30-2011 | 09:55 AM
hispeed-lowdrag
No **** Sherlock. That's why it's a video for the G35. But it's the exact same process lol
Old 01-30-2011 | 09:29 PM
1NEETO's Avatar
1NEETO
Remove drain plug drain oil, replace drain plug with new washer, change filter. Open hood, remove 710 cap add oil, replace 710 cap. The end.
Old 01-30-2011 | 10:16 PM
Bo2point0's Avatar
Bo2point0
I read this question and decided to make a thread in the proper section of the site. Here is the link. Although this is for 2011 Sedan
https://www.myg37.com/forums/general...il-change.html
Old 01-31-2011 | 04:02 AM
Borderline-G37's Avatar
Borderline-G37
O.o just read the manual? thers not many methods that stray away from what most people/the manual do.
Old 01-31-2011 | 09:28 AM
Calgarywinger's Avatar
Calgarywinger
If you're having a hard time removing the used oil filter do this: Take a long screwdriver and jab it through the oil filter, pick a spot as close to the end-cap (away from threads), you're not going to re-use the filter anyway, this gives you a handle to unscrew the filter. Remember to position a container under the filter.
Always grease the new filter's "O" ring and lubricate the threads (I use a dab of the new oil) and you'll find that the filter will never stick again.
Old 01-31-2011 | 12:54 PM
roots4x's Avatar
roots4x
Use this as a LAST DITCH effort. I had to do this once as Infiniti must have replaced one of my filters with a impact wrench! I bent two screwdrivers trying to get the filter out. However, it was a huge mess and I almost ripped the filter to where it would have been nearly impossible to get it out. Do it right and try to get the right filter wrench before attempting this.
EDIT
As long as you do all your own oil changes, I'd suggest just using your hands. Tighten until the filter is sitting on the block then turn 3/4 turn more. It really doesn't have to be on that tight. Also make sure to pour about 1/8 quart of oil in the filter as well as applying some to the gasket.
Old 01-31-2011 | 04:57 PM
terrycs's Avatar
terrycs
Yup ... never crank on the filter super tight. I usually only make 3 quarter turns BY HAND after the filter is seated. Removal should never require more than bare hands (with latex gloves for added grip) if done this way. I don't even have an oil filter wrench.
I've never added oil to the filter before intallation. I would imagine it getting messy since the filter is installed horizontally? I also change my oil with the motor slightly warmed up or hot so oil should already be where it is needed on re-start.
I also suggest using ramps to raise the car for ease of access when removing the lower engine cover.
4DRZ
10-02-2015 09:54 AM
Victory
09-28-2015 10:49 PM
tite_tite
09-25-2015 10:21 PM
cyberone28
09-23-2015 01:56 PM
sharmelan
17
09-14-2015 03:18 PM
Quick Reply: how to change oil?
