The magical "SLIP" light..
Do you understand the meaning of "moderate"?
If there were any possibility of you being right, he'd also be spinning them in 3rd, but he's NOT...
I have a 7AT and ever sicne I put on the winter tires in blinks the slip light once in a while (on perfectly dry pavement) at highway speeds when under hard throtle. I know its not spinnign anything at that speed (not enough power) but its still makes me a little nervous....
The tires are 18s so they are a bit smaller (and a bit narrowe) than the summer 19s the car came with. i would not call it a problem, the tires are just of a less sticky compound so they may have some miniscule slip under hard throttle thats enough to trip the slip light, that's all. I guess if my auto car can do it, the OP's manual car when shifted hard on the highway can trip the slip light too for a brief instant. I would not worry about it.
How you drive may affect how hard you accelerte in 3rd gear vs 4th, but common.... There is no such thing as MODERATE accel with our cars... LOL
^^ lol, yeah, his good neighbor installed it overnight
Went to the dealership and they blame everything on winter tires, the car is perfectly fine and they can not explain it...go figure, did anybody else try the dealer?
Maybe a little more info. Does it come on right after the shift or while already in gear nearing red line? Do you still have the original tires on the car?
4th gear is the closest 1:1 ratio where you will get the most hp and tq from the transmission. If your tires are old and lose their traction this can happen if your giving the car some acceleration and means u need new tires asap.
Christopher Dye
08-24-2015 10:12 AM
Lou@Amplified
Brakes/Suspension
21
05-17-2010 12:38 PM
Skyline-LEXY
Intake and Exhaust
22
02-24-2009 01:11 PM
