Factory Service Manual (FSM) for coupe
Thought I'd share this to the community I paid a membership and got updated NICOs FSM for the G37 and 370z. May want to sticky this.
Factory Service Manual in PDF format.
Index of /FSM/G37
Index of /FSM/G37
The following 16 users liked this post by Fezzik:
Ant1503 (06-17-2016),
Black_G37S (07-12-2014),
Brian Martin (01-27-2020),
Danjjacob (12-24-2014),
digital.aaron (05-09-2022),
and 11 others liked this post.
In the menu, open "GI", general information, see page 5 in the symbols table for the symbols explanations and the torque units. The numbers in the parentheses are torque specs in metric and non-metric units.
Also, pay attention to the color of the torque symbol, white for ft-lb, black for inch-lb; it's all there.
http://www.nicoclub.com/FSM/G37/Coupe/2013/GI.pdf
All this can be found in the FWD chapter of the factory service manual, but I wanted to write this up for people, like me, who didn't know about the FWD chapter.
I would've hyperlinked everything below, but I didn't want to mix up different years/models so I figured writing out the chapter abbreviations would suffice. I also would've posted this in the Coupe section, but the factory service manual thread over there is locked.
General Information
Steering
General Information
- GI - General Information
- ACC - Accelerator Control System
- CO - Engine Cooling System
- EC - Engine Control System
- EM - Engine Mechanical
- EXT - Exterior
- FL - Fuel System
- LU - Engine Lubrication System
- STR - Starting System
- CL - Clutch
- DLN - Driveline
- FAX - Front Axle
- RAX - Rear Axle
- TM - Transaxle & Transmission
- FSU - Front Suspension
- RSU - Rear Suspension
- WT - Road Wheels & Tires
- BR - Brake System
- BRC - Brake Control System
- PB - Parking Brake System
Steering
- ST - Steering System
- STC - Steering Control System
- SB - Seat Belt
- SBC - Seat Belt Control System
- SR - SRS Airbag
- SRC - SRS Airbag Control System
- HA - Heater & Air Conditioning System
- HAC - Heater & Air Conditioning Control System
- VTL - Ventilation System
- ADP - Automatic Drive Positioner
- INT - Interior
- IP - Instrument Panel
- SE - Seat
- BRM - Body Repair
- DLK - Door & Lock
- EXT - Exterior
- GW - Glass & Window System
- PWC - Power Window Control System
- RF - Roof
- SEC - Security Control System
- DEF - Defogger
- EXL - Exterior Lighting System
- HRN - Horn
- INL - Interior Lighting System
- MIR - Mirrors
- WW - Wiper & Washer
- BCS - Body Control System
- CHG - Charging System
- LAN - LAN System
- PCS - Power Control System
- PG - Power Supply, Ground, & Circuit Elements
- PWO - Power Outlet
- AV - Audio, Visual & Navigation System
- MWI - Meter, Warning Lamp & Indicator
- SN - Sonar System
- WCS - Warning Chime System
- CCS - Cruise Control System
- MA - Maintenance
The following 3 users liked this post by Melophile:
superjoey
31
03-22-2023 11:56 PM
