Dash Recall
Probably. My cluster lid was last replaced around August, the top of the lid looks to be the same construction as before.
Looks like the lids are available on ebay if warranties have expired...not cheap:
http://cgi.ebay.com/ebaymotors/OEM-I...Q5fAccessories
Hey guys,
If anyone can find that TSB that would be greatful. I searched: INFINITI G37 COUPE Technical Service Bulletin ID:17730 - For INFINITI G37 COUPE and couldn't find anything.
Is there another website? Also, that cracking sound would be great if it was a TSB! That way I can shove it in the dealerships face and make them fix it once and for all.
In my experience, whenever something is taken apart by a dealer, there is a chance for something else going wrong. It's hard to duplicate the factory fit. My steering wheel column plastics (by the paddles) had to be replaced after each lid replacement because they were damaged. Now the back of my steering wheel plastic sometimes rubs up on those plastics and makes a grinding noise.
This is a really bad quality issue for Infiniti which should have been caught when the car was first being designed. I'm sure they know the lid peels over time, must have been cheaper to design it this way. Overall, the interior in the G37 seems to be an improvment from previous offerings, but it can't compete with it's rivals in quality.
Haven't seen a TSB yet, but an updated part should be built that uses clips (at a minimum) to hold the lid together. The EX35 is designed this way.
#30
is it this one? https://www.myg37.com/forums/tsb-tec...dash-area.html or something new?
