Sponsored By:
Sponsored By:
Uncle SRG wants you!
Old 11-05-2010, 10:27 AM
SRG
SRG's Avatar
Originally Posted by wakeboardr116
All spacers do is push the wheels out on the car.
I rubbed on the bumper bracket slighty but was able to trim it, but thats also with wider tires. With the Eibach springs I will admit they are pretty bouncy at times. If you are worried about ride quality than you should just go with a set of coilovers. That way you can adjust everything how you want. A lot of people say the Tanabe coils ride really well.
thanks a lot for the help...g37Sam's car has badass stance. I think i'll also go with Stoof's advice on the rims. Gotta take baby steps, especially in this crappy weather in Philly. I'm definitely thinking of Vossen Wheels in the spring. So in the winter i'll focus on the headlights and get those tailights with the GTR look done. Then in the spring do the goods to the car.
Old 11-05-2010, 11:01 AM
wakeboardr116
wakeboardr116's Avatar
Those pics are of my car. Me and sam have pretty much identical setups. lol
Old 11-05-2010, 11:08 AM
SRG
SRG's Avatar
oh ok LOL well then your stance is badass too!
Hopefully soon i'll be doing that. definitely like the way it looks.
hows the ride for you? i mean comparing it to the stock suspension.
Old 11-05-2010, 11:09 AM
TheIvoryG
TheIvoryG's Avatar
Wakeboard what size tires are you running?
Old 11-05-2010, 11:19 AM
jdkno
jdkno's Avatar
Wakeboard, how much of a drop does your car have? Also if you didn't have the drop do you think you would have any rubbing problems?
By far I think what you have is the cleanest look I have seen so far, I can't stand when people stretch a smaller tire to fit on a larger rim and the sidewall goes in at a 45 deg. angle instead of straight up. I think if SRG had the stock wheels painted the dark gunmetal color from the GTR's with the same set up as yours it would look killer.
Old 11-05-2010, 11:27 AM
wakeboardr116
It is quite a bit stiffer but I also have sway bars. The eibachs do ride rougher than stock though.
Old 11-05-2010, 11:33 AM
wakeboardr116
275/35 rear and 245/40 front.
Old 11-05-2010, 11:51 AM
TheIvoryG
TheIvoryG's Avatar
Perfect...I think that is what I'm going to go to when my stocks run out. Looks great, very well done job!
Old 11-05-2010, 11:52 AM
wakeboardr116
It dropped just under 1.5" in the front and about 1" in the rear. Before the drop there was no rubbing at all.
Old 11-05-2010, 11:53 AM
wakeboardr116
Thanks man.
Old 11-05-2010, 12:06 PM
SRG
SRG's Avatar
i think thats what i'm going to do, thanks man
Old 11-05-2010, 01:03 PM
Gthirty7_S
Gthirty7_S's Avatar
I'm also dropped on Eibachs with stock 19's and thinking about 20mm spacers all around. Can you please explain about the rubbing problems you've experienced? When I'm driving and hit dips in the road, I can hear the tires rub real quick sometimes. Will this get much worse once I install the spacers? Thanks
Old 11-05-2010, 01:17 PM
wakeboardr116
It might rub the wheel liner a little more on bumps, but the main thing was the rear tire rubbing the bumber bracket. I just trimmed it back with a drimmel and now it doesnt rub it any more.
What size tires are you running though?
Old 11-05-2010, 04:50 PM
  #29
Gthirty7_S
Gthirty7_S's Avatar
I've got 275/35 on the rear and 245/40 on the front. Do you think that will work? I don't want to have to modify the fender too much to avoid rubbing.
Old 11-05-2010, 09:59 PM
  #30
wakeboardr116
Those are the same widths I'm running. If you go 20mm spacers you might have to trim the bracket just a bit. If you are to worried about it you could go with 15mm and should be fine.
JohnnysG
Photoshop
03-14-2011 06:39 PM
Quick Reply: Uncle SRG wants you!
