Sponsored By:
Sponsored By:
A Bit Juvenile: Peeling out in the auto?
Old 09-20-2010, 05:54 AM
xlack
xlack's Avatar
man that's easy. From stop, DS mode, VDC off, then slam on the gas. i tried it before and it works lulz..
Old 09-20-2010, 07:57 AM
cereal2k
Mr. Drop it like it's hot
cereal2k's Avatar
Originally Posted by ScottyBeGood
Here read and try this.
interesting
Old 09-20-2010, 08:02 AM
beerme986
beerme986's Avatar
i just turn vdc off, put the car in first and gas away. pretty easy for me to burn rubber ..even on yoko s drives.
Old 09-20-2010, 09:02 AM
surfjax87
surfjax87's Avatar
One night I had a giant empty parking lot, turned vdc, DS, punched it and...nothing. Just a hard acceleration. It seems I'm better at breaking the tires loose when I'm not trying to.
It's seems a lot easier for me to burn out when in manual mode, let off the brake in 1st, get on the gas to about 3-4k and then floor it.
Old 09-20-2010, 10:32 AM
JohnEnglish
JohnEnglish's Avatar
Yeah, it's pretty easy. Just turn off VDC and floor the gas.
Old 09-20-2010, 10:35 AM
Blackjack
Blackjack's Avatar
Where's Chekov?
Old 09-20-2010, 02:18 PM
Alex57r
Alex57r's Avatar
Some people say their 08s peel out like there is no tomorrow, but this is highly doubtful. I have test driven an 08 5at coupe which absolutely could not even squeek a tire. The 09s+ are suppsedly geared a little more aggresively, but in all the videos out there (youtube etc) these cars just do not peel out off the line in automatic. PERIOD. Someone please prove me wrong... lol
http://www.youtube.com/watch?v=y1eRI...eature=related
Having said that, I know for a fact that even the AWD cars 09+ chirp second gear from time to time. When I am alone in the car with no extra weight on some types of road surface it will just do it on its own, I don't need to do anything other than be on the throttle at 1-2 shift speeds.
Old 09-20-2010, 02:50 PM
ChrisBLKG
ChrisBLKG's Avatar
That's funny cause I have an 08 5AT and it seems that my tires always squeal under normal (to me) acceleration.... With plenty of treadlife left on the rears...
Simply press the gas a little harder and it will do it VDC or not... I've only turned it off a couple of times.. Maybe it's my driving idk lol
Old 09-20-2010, 04:18 PM
JohnEnglish
Yeah, same here, it's really easy to break the rear end lose with VDC off.
Old 09-20-2010, 06:29 PM
CateyeRR
CateyeRR's Avatar
I'm pretty sure a lot of you are having problems because the throttle is programmed not to go to 100% immediately in lower gears. Infiniti did it for driveability and less jerkiness. I'm sure someone can chime in that knows more about it than I do. You can have it removed with a tune.
Old 09-21-2010, 01:33 AM
Mazaki
Mazaki's Avatar
That would be perfect: when the tranny in in Auto, have an economy mode. Then, when in manual mode, it goes sporty. I remember when I got to test drive an auto 2004 M3. That puppy was smooth as silk in A, then when you threw it into M, it was like driving a lambo. Floor it and the wheels would squeal.
Any way to program the G like this? I know the car has the power, the issue is the ECU allowing it... Like, recognizing a to the floor stomp, and releasing the clutch quickly to acheive a peel.
Is there any tuning or electronic way to program the ECU to actually open the throttle 100% when I floor the pedal?
Damnit, none of this would be a problem if I had just gotten the manual.
Old 09-21-2010, 02:07 AM
G37Sam
G37Sam's Avatar
Originally Posted by Blackjack
Where's Chekov?
Damn I was thinking the same thing haha
Old 09-21-2010, 07:57 AM
bschurr
bschurr's Avatar
This is one of the funniest threads I have ever read on a car forum!
In an auto, dont forget to crank the steering wheel before you launch to lighten the rear end. The rear tires will light up like a Christmas tree. If anyone needs help, I am available for burn out instruction (in your car) for a nominal fee...
Old 09-21-2010, 08:05 AM
  #29
Blackjack
Blackjack's Avatar
Old 09-21-2010, 08:45 AM
  #30
thebaran06
thebaran06's Avatar
let some air out of the tires, or take a turn at 45mph
Quick Reply: A Bit Juvenile: Peeling out in the auto?
