Proper way to back up to drive way with MT?
I feel like i'm riding a clutch when i back up to my drive way. Do you guys let go of the clutch completely when you back up to the drive way or garage? i usually use clutch to go in and out to slow things down with a little bit of gas. Am i doing it right?
Thanks
Thanks
Any time the clutch pedal is not fully engaged or disengaged, you're causing some degree of wear on it. So try not to use the clutch pedal as a means to regulate your speed. You can crawl at a really low speed in 1st/reverse without stalling, so there's really no reason to clutch a lot in your driveway.
I use the clutch with some gas. If you want to let go of the clutch completely, be prepared to brake because it will be back up pretty quickly.
__________________
__________________
If I had a 20-foot driveway, I could see using a combination of the clutch/gas/brake to regulate speed. But to say that you should never use the gas pedal to reverse a manual transmission car just seems silly to me.
Well, I guess that depends upon a few factors. My driveway is more than 100 feet long and I like to back up the driveway (makes for quick getaways!) very often. So I do in fact completely engage the clutch and use the gas & brake pedals to control my speed.
Thirty_Seven
12
08-16-2015 01:48 PM
