Question about the push-button start
Sorry about my noob question, but I am new to this whole push-button start concept... When I am starting the car, do I hold the button for a second until the engine turns over like I would with a normal car? Or do I just press the button once and the car will start by itself?
just push it and let go. you don't need to hold it down.
you can push it 2x quickly to turn on the electronics, etc.
here is the manual so you can read all about your G: http://www.infiniti-techinfo.com/ref...finiti-G37.pdf
what he said. i was playing around with it and discovered the electronics on technique.
Also if you double tap it while the car is on it will turn the engine off and keep the stereo on.
Neat stuff.
Neat stuff.
^no
abcd
abcd
My infiniti dealer told me the FOB doesn't charge your battery
I've stuck it there for hours and nothing happened, still get the low battery indicator
Nah it doesn't charge the fob's battery Sam...just if the fob battery is dead it will prevent you from starting the car (b/c the car will think there is no fob at all) and so putting it in the slot makes the car recognize it.
But the only way to "charge" the fob is to change the battery
