Sponsored By:
Sponsored By:
Some days my G drives better than others....
Old 05-20-2010, 11:43 AM
Mike
Mike's Avatar
Originally Posted by Breitling65
Speaking of low octane, just come back from Europe where my friends making fun of us driving on 93. Most on 95/98 there and per their words difference is huge. Don't get cheap, use good/best gasoline on G. No point to me of spending such $ on mods as you and use 91.
Our gas is (MON+RON)/2. Euro gas is just RON; their 95 is roughly our 91 and their 98 is roughly our 93.
Old 05-20-2010, 11:54 AM
VossenG37S
VossenG37S's Avatar
Originally Posted by Gamedog
You'll want to use at least 91 at all times IMO.
Might be why your car is running funny at times
Our cars do love cool weather tho thats for sure.
Very true because some days when it's nice and cool especially at night here in Miami my G just feels perfect and faster then days when it's hot and humid here and my G lags the performance that I wonder is it just me or the car lol. But agree that Z/G love cold weather .
Old 05-20-2010, 12:27 PM
JLai
JLai's Avatar
Has no one here heard of heat soak?
Old 05-20-2010, 02:27 PM
owslystnly
owslystnly's Avatar
Only time i notice my G driving differently is when the traction control kicks in and cuts some of the engine power to prevent me from looking like a fool in the ditch.
Old 05-20-2010, 02:32 PM
eksigned
eksigned's Avatar
There's a reason why Infiniti recommends the use of premium. Higher octanes to prevent pinging and retarded (HAH! edit: retardation), correct? Why go between the different octanes? I've heard around that using a higher octane than recommended doesn't really do any good for cars in general, but then again...I have a friend who claims that higher octane gasoline in INFINITI/NISSANS actually do some good (shot at your 93 octane Sun gas)...maybe?
On a side note, you're probably getting that "lag" from heat soak. I've learned that without starting the car and letting it idle for a bit...the car isn't as peppy in the mornings...yes, yes I know the best way to warm up the car is via driving it; it idles rough (misfires) for a reason...blah blah blah...just my 2cents.
Old 05-20-2010, 07:15 PM
mike904
mike904's Avatar
I've casually looked for 91 octane and have yet to find it here in NE Florida. So I'm stuck using the 93 octane (with higher price).
Old 05-22-2010, 09:07 PM
thegad
thegad's Avatar
The cool weather has a huge effect on the G . There's an on ramp that I like to take advantage of on my daily commute to work, and on one particular morning when the engine was well warmed up but the temp outside was cool I was actually startled by how urgently the G accelerated. It was a truly significant difference.
Old 05-22-2010, 09:52 PM
EnviedG35
EnviedG35's Avatar
Cooler, less humid air has higher oxygen density. Therefore more combustion per stroke. Humid air is less dense, and contains more water, which we know is not combustible. Even on two equally hot days, the day where the humidity is lower, the car will probably feel more repsonsive than it would be with high humidity in the air.
Old 05-22-2010, 10:11 PM
2008G-Man
2008G-Man's Avatar
Question here, I have noticed that in the mornings or when the car hasn't run for a while (regardless of outside temp), it does run rough when first started up. After 15-30 seconds it smooths out. Is there a reason?
Old 05-22-2010, 10:13 PM
2008G-Man
2008G-Man's Avatar
When I had my bike (suzuki 750) it ran Soooo much better when the day got cooler, around dusk. It was very obvious.
Old 05-22-2010, 11:32 PM
Boomer-Bob
Boomer-Bob's Avatar
Could be richer while motor gets to temp?
Old 05-23-2010, 09:04 AM
mike904
mike904's Avatar
When air is cooled, it become denser, allowing our engine to burn more fuel and produce more power. We can see the reverse affect driving up a mountain - the higher you get, the air becomes less dense and the engine produces less power. Of course, this is assuming humidity remains constant - as you said, when humidity increases, the air density decreases.
Regardless of density, the oxygen level is still 21%.
Old 05-23-2010, 07:56 PM
Jamler
Jamler's Avatar
... I hit VDC every time i get in; Unless its raining...
Old 05-25-2010, 06:47 AM
  #29
eksigned
eksigned's Avatar
G,
We need to have a talk . I'm no expert, but from what I can understand, the rough idle that you're talking about is the car's ULEV system (or whatever equivalent system we have - remember, I'm coming from a 2005 Acura TL). Anyways, the car misfires upon start up to help the car warm up (that's the rough idling for the few seconds that you're talking about).
By the way, I posted a reply in another thread about your RP comment. DON'T USE RP! It's not junk, but certainly not worth the extra $$$ you're spending for it.
Old 05-25-2010, 08:54 AM
  #30
2008G-Man
2008G-Man's Avatar
thanks for your thoughts ... there are a lot of thoughts on RP that say just the opposite. When I'm due for the next oil change I plan on sending some off to Blackstone. Bottom line, I want to do what's best for the longevity of my car, we plan on keeping it a long time.
Manny735
08-14-2017 09:25 AM
redlinernyc
02-29-2016 11:06 PM
Detailed Image
Lighting/Cleaning Products
09-04-2015 08:14 AM
ZachThomas
09-03-2015 01:40 PM
Quick Reply: Some days my G drives better than others....
