whats the proper way to downshift brake
#46
One of the most common misconceptions about downshifting, you CAN skip gears! Your transmission does NOT need to go in order when shifting up or down. Don't get me wrong, its not great to go from first gear at 3k RPM's to sixth, but if you are getting on it in third gear and change into sixth to cruise then there is nothing wrong with that.
Some people say its bad in general to skip gears period.
#47
Skipping gears is fine, but rev-match is much harder. If you're doing 2k in 5th doing about 60mph, do you know what rpm you have to be at in 3rd? It's not just a blip of the throttle anymore, but rather revving to something like 6-6.5k rpm. That's what makes it harder.
#50
Engine ->clutch<- Midshaft ->transmission<- wheels
Your clutch connects the midshaft and engine together, and your trans connects the midshaft and wheels together. This way, if the Clutch is disengaged, or the trans is in neutral, there is a break in the "train" and you cannot put power down to the ground through the wheels.
The Clutch allows for a difference between the engine and midshaft speed to be "scrubbed off". E.g. when you start from a dead stop, you clutch in, disconnecting the engine and midshaft, go into gear, connecting the midshaft and wheels. Remember, the midshaft was spinning at the same speed as the engine before you clutched in, so the synchros are bringing down midshaft speed to the appropriate speed by slipping to match a ratio with the wheels, Zero in this case since you're stopped. Then you start slipping the clutch to allow power to go down to the wheels until you're going fast enough that you can stop slipping.
Now, lets start with clutch load. If you do a redline start, slipping the clutch, it's obviously going to put much more load (and consequently wear) on the clutch, right? Going to that 6th gear synchro, if you did a redline shift from 5th gear, you'll get roughly a 1800 RPM drop. The 6th gear synchro was designed specifically with that load in mind; during normal driving conditions, the synchro should never match up more than that, and usually much less.
When you skip from say.. a redline 3rd gear shift to 6th, you're now putting a ~4000 RPM load on the synchros. This energy works in powers; you're putting not a ~2.3x load, but a ~2.3² amount in load, so in reality, close to 5x the load the synchros were designed for.
Instead, what you can do is Clutch in, move the shifter into 4th, then 5th, then 6th, and then clutch out. This breaks up that load into smaller increments. Yes, the engine is not connected, but the midshaft and trans are connecting every time you go into gear, and the synchros for each gear are doing a smaller portion of the work. Most importantly, the load each gear is taking on is one that the synchro is designed to handle.
When I'm downshifting multiple gears, I still don't skip gears. The only REAL reason anyone would skip gears downshifting is if you're street racing; I doubt you'd ever need ALL 330 horses for an emergency maneuver. On the track, you can heel-toe downshift multiple times during braking with absolutely no affect on performance if you can do it well. If you're not doing some serious racing, you'll have ABS anyways.
#51
Mike: I was talking about down shifting. Yes you should never skip a gear while shifting up to a gear that is bad in general but in down shifting if you can rev match down shift to a gear it won't do a lot of damage. On the other hand if you mess up on the rev matching than it does a world amount of damage depending the gear and rpm.
CrazyJayZ: It's called knowing your car. Actually, at 60 you can rev match to 2nd at 7k get that extra power and upshift to 3rd but like you said if you want to go to 3rd it should be about 6k-6.5k
#52
Downshifting and upshifting put the same type of load on the synchros, but downshifting a gear rarely creates as large of a RPM gap.
Revmatching does nothing to bring the midshaft speed up, which is what the synchros are doing. It only brings the engine speed up. Ever try to go into 1st at 30 mph? You can, if you gently push up long enough on the shift ****. You'll hear a whine that gets higher pitched. That's the synchros spinning up the midshaft up fast enough so that your trans can get into gear. Do you think revmatching a 2->1 shift will make it any easier to move your shift lever?
#53
37
10-17-2020 12:12 PM
timc00k
02-15-2017 10:15 AM
Mattimus
10-04-2015 02:33 PM
FlyIce
09-29-2015 05:07 AM
